Problem of upgrading homeassistant from 0.91.4 to 0.92.0
problem solved. upgrading python 3.5.3 to 3.7.3
I need help, I can`t upgrade my HA from 0.91.4 to 0.92.0。
Device: Raspberry 3B +
OS: Raspbian
Problem details as follows:
pip3 install --upgrade homeassistant
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Collecting homeassistant
  Using cached https://files.pythonhosted.org/packages/bb/94/dd2d566a504310e386da1ea9fe29547aab102ec87342411d7c8cf9d619e6/homeassistant-0.92.0-py3-none-any.whl
Requirement already satisfied, skipping upgrade: aiohttp==3.5.4 in /usr/local/lib/python3.5/dist-packages (from homeassistant) (3.5.4)
Collecting cryptography==2.6.1 (from homeassistant)
  Using cached https://files.pythonhosted.org/packages/07/ca/bc827c5e55918ad223d59d299fff92f3563476c3b00d0a9157d9c0217449/cryptography-2.6.1.tar.gz
  Installing build dependencies ... done
  Getting requirements to build wheel ... done
ERROR: Exception:
  File "/usr/local/lib/python3.5/dist-packages/pip/_internal/cli/base_command.py", line 178, in main
    status = self.run(options, args)
  File "/usr/local/lib/python3.5/dist-packages/pip/_internal/commands/install.py", line 352, in run
    resolver.resolve(requirement_set)
  File "/usr/local/lib/python3.5/dist-packages/pip/_internal/resolve.py", line 131, in resolve
    self._resolve_one(requirement_set, req)
  File "/usr/local/lib/python3.5/dist-packages/pip/_internal/resolve.py", line 294, in _resolve_one
    abstract_dist = self._get_abstract_dist_for(req_to_install)
  File "/usr/local/lib/python3.5/dist-packages/pip/_internal/resolve.py", line 242, in _get_abstract_dist_for
    self.require_hashes
  File "/usr/local/lib/python3.5/dist-packages/pip/_internal/operations/prepare.py", line 368, in prepare_linked_requirement
    abstract_dist.prep_for_dist(finder, self.build_isolation)
  File "/usr/local/lib/python3.5/dist-packages/pip/_internal/operations/prepare.py", line 175, in prep_for_dist
    self.install_backend_dependencies(finder=finder)
  File "/usr/local/lib/python3.5/dist-packages/pip/_internal/operations/prepare.py", line 123, in install_backend_dependencies
    reqs = req.pep517_backend.get_requires_for_build_wheel()
  File "/usr/local/lib/python3.5/dist-packages/pip/_vendor/pep517/wrappers.py", line 71, in get_requires_for_build_wheel
    'config_settings': config_settings
  File "/usr/local/lib/python3.5/dist-packages/pip/_vendor/pep517/wrappers.py", line 162, in _call_hook
    raise BackendUnavailable
pip._vendor.pep517.wrappers.BackendUnavailable
Are you using a venv? If so did you ‘activate’ it?
I am not using venv.
when I install cryptography separately, also the same problem.
I can install cryptography 0.25,but I can`t install cryptography2.6.1( HA0.92 needed)
OK, I am and it worked for me using pip. However I don’t know enough about pip to diagnose further. If I find anything I’ll let you know.
I was in venv on raspbian and I’ve got some problems…solved installing some packages before upgrade…
sudo apt-get install build-essential libssl-dev libffi-dev python3-dev
…as described here…
I installed those packages as you said
it also not works
Problem solved. upgrading Python 3.5.3 to 3.7.3。
the Python upgrade solve my problem, thanks
How do I upgrade python to home assistant in docker container?
Thanks,
I have hass 0.91.4 on raspberry Pi 3 and i try to update got error
" Installing build dependencies error" and then a bunch of red text like 2-3 pages.
should i update python to 3.7.3, how do i do it?
From your home folder on your Raspberry Pi type the following
sudo apt-get install libssl-dev
Once complete upgrade as usual. The red stuff you refer to I imagine refers to cryptography issues which the above solved.
This tip compliments to @anon34565116 which solved my problem.
I tried the install of libssl-dev yesterday and that did not help.
today i rdp to my rpi and try to run the update of home assistant and it gets stuck at
Building wheels for collected packages: cryptography
Building wheel for cryptography (PEP 517) … \
then freezes then i close and open rdp again and the session is lost, not sure if rpi is rebooting.
update: the next rdp session i connected and try run the update again, and it froze at same point but this time i lost rdp and never able to get back. I guess i have to call home to reboot the rpi
Update: After an hour or so i tried connecting to my pi and i see HS got updated.
I have no idea why it froze in first place. hopefully it does not happen again on next update.
During the update it didn’t freeze. It was building PEP 517 cryptography. Takes quite a while but as you see it worked and resolved your issue.
