Problem re-uploading code to ESPHome
I wanted to update one of my devices running ESP Home.
Its a Magic Home LED controller that I’ve flashed with ESP home and while it worked fine the first time I flashed it I wanted to change the code a little bit and got this error message telling me that I’m not connected to the internet.
I’m right now on 0.111.2
As for the ESPhome Yaml file - I’m confident that its OK (It worked the first time and I have ~14 other devices with similar code that is OK (With the exception of another one but it’s a different symptom).
Anyone have any suggestions on what could be wrong in this case ?
INFO Reading configuration /config/esphome/raindance_esp_rgb_strip_4.yaml...
INFO Generating C++ source...
INFO Compiling app...
INFO Running:  platformio run -d /config/esphome/raindance_esp_rgb_strip_4
Processing raindance_esp_rgb_strip_4 (board: esp01_1m; framework: arduino; platform: [email protected])
HARDWARE: ESP8266 80MHz, 80KB RAM, 1MB Flash
Looking for ESPAsyncTCP-esphome library in registry
Warning! You are not connected to the Internet.
If you build a project first time, we need Internet connection to install all dependencies and toolchains.
Looking for ESPAsyncWebServer-esphome library in registry
Dependency Graph
|-- <ESP8266WiFi> 1.0
|-- <ESP8266mDNS> 1.2
|-- <DNSServer> 1.1.1
Compiling /data/raindance_esp_rgb_strip_4/.pioenvs/raindance_esp_rgb_strip_4/src/esphome/components/api/api_connection.cpp.o
Compiling /data/raindance_esp_rgb_strip_4/.pioenvs/raindance_esp_rgb_strip_4/src/esphome/components/api/api_server.cpp.o
Compiling /data/raindance_esp_rgb_strip_4/.pioenvs/raindance_esp_rgb_strip_4/src/esphome/components/api/list_entities.cpp.o
Compiling /data/raindance_esp_rgb_strip_4/.pioenvs/raindance_esp_rgb_strip_4/src/esphome/components/api/subscribe_state.cpp.o
In file included from src/esphome/components/api/list_entities.h:52:0,
                 from src/esphome/components/api/list_entities.cpp:1:
src/esphome/components/api/api_server.h:19:25: fatal error: ESPAsyncTCP.h: No such file or directory
* Looking for ESPAsyncTCP.h dependency? Check our library registry!
* CLI  > platformio lib search "header:ESPAsyncTCP.h"
* Web  > https://platformio.org/lib/search?query=header:ESPAsyncTCP.h
 #include <ESPAsyncTCP.h>
compilation terminated.
In file included from src/esphome/components/api/api_connection.h:7:0,
                 from src/esphome/components/api/api_connection.cpp:1:
There’s an issue open:
Workaround: install the dev version.
I see.
So two questions.
  1. Where do I find the dev version ?
  2. I have another device with the same YAML content. On this I get the following error:
INFO Reading configuration /config/esphome/raindance_esp_rgb_strip_2.yaml...
INFO Running:  platformio run -d /config/esphome/raindance_esp_rgb_strip_2
Processing raindance_esp_rgb_strip_2 (board: esp01_1m; framework: arduino; platform: [email protected])
InvalidJSONFile: Could not load broken JSON: /data/raindance_esp_rgb_strip_2/.piolibdeps/raindance_esp_rgb_strip_2/ESPAsyncWebServer-esphome_ID6758/.library.json:
  File "/usr/local/lib/python3.6/dist-packages/platformio/builder/main.py", line 126:
    env.SConscript("$BUILD_SCRIPT")
  File "/root/.platformio/packages/tool-scons/script/../engine/SCons/Script/SConscript.py", line 605:
    return _SConscript(self.fs, *files, **subst_kw)
  File "/root/.platformio/packages/tool-scons/script/../engine/SCons/Script/SConscript.py", line 286:
    exec(compile(scriptdata, scriptname, 'exec'), call_stack[-1].globals)
  File "/root/.platformio/platforms/espressif8266/builder/main.py", line 203:
    target_elf = env.BuildProgram()
  File "/root/.platformio/packages/tool-scons/script/../engine/SCons/Environment.py", line 224:
    return self.method(*nargs, **kwargs)
  File "/usr/local/lib/python3.6/dist-packages/platformio/builder/tools/platformio.py", line 122:
    _build_project_deps(env)
  File "/usr/local/lib/python3.6/dist-packages/platformio/builder/tools/platformio.py", line 47:
    project_lib_builder = env.ConfigureProjectLibBuilder()
  File "/usr/local/lib/python3.6/dist-packages/platformio/builder/tools/piolib.py", line 1043:
    project.install_dependencies()
  File "/usr/local/lib/python3.6/dist-packages/platformio/builder/tools/piolib.py", line 867:
    if lm.get_package_dir(*lm.parse_pkg_uri(uri)):
  File "/usr/local/lib/python3.6/dist-packages/platformio/managers/package.py", line 419:
    manifest = self.get_package(name, requirements, url)
  File "/usr/local/lib/python3.6/dist-packages/platformio/managers/package.py", line 387:
    for manifest in self.get_installed():
  File "/usr/local/lib/python3.6/dist-packages/platformio/managers/package.py", line 377:
    manifest = self.load_manifest(pkg_dir)
  File "/usr/local/lib/python3.6/dist-packages/platformio/managers/lib.py", line 68:
    manifest = BasePkgManager.load_manifest(self, pkg_dir)
  File "/usr/local/lib/python3.6/dist-packages/platformio/managers/package.py", line 345:
    manifest = fs.load_json(manifest_path)
  File "/usr/local/lib/python3.6/dist-packages/platformio/fs.py", line 57:
    raise exception.InvalidJSONFile(file_path)
========================== [FAILED] Took 1.59 seconds ==========================
Anyone know what this is about and how to fix it?
I’ve search “all over my Raspberry Pi4” but can’t find any of the referenced file.
In the ESPhome repository ( GitHub - esphome/home-assistant-addon: ESPHome Home Assistant Add-on ) in the addon store:
