chiten
(Francisco Rivas)
October 1, 2020, 3:12am
1
Hi all!
I am really new with this system and not so familiar with the coding. I have been trying for a few days but could not make it work.
I am trying to set an automation to irrigate my hydroponics according to input helpers where I set the following:
start of daylight period
Irrigation frequency for daylight period
start of night period
Irrigation frequency for night period
Time of irrigation (same for both periods)
So, depending of the time of the day it should irrigate at a different frequency. Here is the code I am using:
- id: '1601263156762'
alias: Sistema riego por tiempo
description: ''
variables:
frecuencia_riego: >
{% if input_number.inicio_intervalo_diurno < now().hour < input_number.inicio_intervalo_nocturno %}
"{{states('input_number.frecuencia_de_riego_diurno') | int}}"
{% else %}
"{{states('input_number.frecuencia_de_riego_nocturno') | int}}"
{% endif %}
- platform: time_pattern
hours: '*'
minutes: "/{{frecuencia_riego}}"
seconds: '*'
- service: switch.turn_on
data: {}
entity_id: switch.sonoff_100090196f
- delay: "00:{{input_number.tiempo_de_riego}}:00"
- service: switch.turn_off
data: {}
mode: single
The error I get is:
Invalid config for [automation]: invalid time_pattern value for dictionary value @ data[‘minutes’]. Got None. (See /config/configuration.yaml, line 10).
Trying to debug something, I found that if I change " minutes: “/{{frecuencia_riego}}” to " minutes: ‘/10’ " the error dissapears but does not work either.
Any help somebody could give me will be higle appreciated. Thanks!
Hellis81
(Hellis81)
October 1, 2020, 3:44am
2
What is frecuencia_riego and where is it set?
tom_l
October 1, 2020, 5:08am
3
This key is not currently templateable.
chiten
(Francisco Rivas)
October 1, 2020, 10:40pm
4
Hi!
frecuencia_riego should be the frecuency of irrigation. Depending of the time of the day it should be set according to two input_numbers. This is:
The day is dived in to intervals set by two input numbers ´( input_number.inicio_intervalo_diurno and input_number.inicio_intervalo_nocturno)´
|-------------interval 1--------------------|-----------interval 2--------|
Each interval has its own frecuency setted by two different input numbers ´(input_number.frecuencia_de_riego_nocturno and input_number.frecuencia_de_riego_nocturno)´
chiten
(Francisco Rivas)
October 1, 2020, 10:44pm
5
Thanks for your answer!
Do you know if there is any way to set a variable time_pattern trigger?
tom_l
October 1, 2020, 10:54pm
6
I think you could do it like this:
platform: state
entity_id: input_boolean.whatever
to: 'on'
for:
minutes: "{{frecuencia_riego}}"
- service: input_boolean.turn_off
- your actions here
chiten
(Francisco Rivas)
October 2, 2020, 2:34am
7
Thank you Tom, you gave an idea using states as triggers. I made two differents automations, one for each interval, and changed input_number for input_datetime. Maybe it is not the most efficient way of doing it but is working.
Interval between start and end time:
- id: '1601594803344'
alias: Riego diurno
description: ''
- platform: state
for: 00:{{ states('input_number.frecuencia_de_riego_diurno') | int}}:00
to: 'off'
condition:
- condition: time
after: input_datetime.inicio_intervalo_diurno
before: input_datetime.inicio_intervalo_nocturno
data: {}
- delay: 00:{{ states('input_number.tiempo_de_riego') | int }}:00
data: {}
mode: single
Interval for the rest of the day:
- id: '1601596411913'
alias: Riego nocturno
description: ''
- platform: state
for: 00:{{ states('input_number.frecuencia_de_riego_nocturno') | int}}:00
to: 'off'
condition:
- condition: time
after: input_datetime.inicio_intervalo_nocturno
before: input_datetime.inicio_intervalo_diurno
data: {}
data: {}
mode: single
