Problem setting homeassistant.service and PID climate target temperature
Hello everyone. I have problems to put things together and need your help.
i want to switch from ha-pid-controller to ESPHome PID climate. In homeassistant i use custom VEsync with a Classic300S Humidifier.
I managed to set up PID Climate based on this code. I use ledc for PWM.
##Edit - short update:
I need help to
  • set default_target_temperature with id: RH_ZIEL (solved)
  • set mist level based on id: rh_output_level (solved)
  • insert global mist_level instead of ‘8’ in script (see post 4, there is the complete script)
value: '8' #'mist_level' #!lambda 'return mist_level;'
Here is the relevant code fro PID Climate:
climate:
  - platform: pid
    name: "PID Humidity Controller"
    sensor: RH_MITTELWERT
    default_target_temperature: 70 °C
    heat_output: pwm_output
    visual:
      min_temperature: 30
      max_temperature: 80
    control_parameters:
      kp: 0.30606
      ki: 0.00319
      kd: 7.34541
      output_averaging_samples: 5      # smooth the output over 5 samples
      derivative_averaging_samples: 5  # smooth the derivative value over 10 samples
    deadband_parameters:
      threshold_high: 2°C       # deadband within +/-0.5°C of target_temperature
      threshold_low: -2°C
button:
    name: "PID Climate Autotune"
    on_press:
      - climate.pid.autotune: pid_humidity_controller
output:
  - platform: ledc
    pin: GPIO39
  - platform: pid
    name: "RH Output Level"
    climate_id: pid_humidity_controller
    type: HEAT
Thank you in advance
Schnabulator
This looks wrong. turn_turn_on? Surely not!
Hello
sorry - you are absolutely right.
The code above is WIP including the part i need help with :slight_smile:. I correct my initial post.
In ha the following automation works great.
Downside is sending massive sensor data from esp home to home assistant (for “fast” reaction of the humidifier). Another thing is that the humidifier start with mist level 1. My workaround is setting mist static to level 6 (pid > 0).
To be clear i need help to write data from a template sensor on ESPHome
  • id: RH_ZIEL values in climate.esp_pid_humidity_controller directly on the ESP.
  • turn on / off the domain humidifier in HA
alias: ESPHome PID Controller Luftbefeuchter Ansteuerung
description: ""
  - platform: time_pattern
    seconds: /10
condition: []
  - service: climate.set_temperature
      temperature: "{{ states('sensor.esp_rh_ziel') }}"
      entity_id: climate.esp_pid_humidity_controller
  - if:
      - condition: numeric_state
        entity_id: sensor.esp_rh_output_level
        above: "0"
    then:
      - type: turn_on
        device_id: 8087b5018bbe0c6d1de2a789d8b5c9a2
        entity_id: 1f5fa2674733027e2665ed63e0a603de
        domain: humidifier
      - delay:
          hours: 0
          minutes: 0
          seconds: 2
          milliseconds: 0
      - service: number.set_value
        metadata: {}
          value: "6"
          entity_id: number.classic300s_mist_level
        enabled: true
      - if:
            entity_id: sensor.pid_humidity
            above: 30
        then:
            metadata: {}
              value: "6"
        else:
            metadata: {}
              value: "4"
        enabled: false
    else:
      - type: turn_off
        domain: humidifier
mode: single
short update:
  • set default_target_temperature with id: RH_ZIEL is solved.
  • setting mist_level works
ToDo:
complete script:
globals:
  - id: "mist_level"
    type: float #int
    restore_value: no
    initial_value: '1'
script:
  - id: luftbefeuchter_an_mistlevel
    then:
      - homeassistant.service:
          service: homeassistant.turn_on
            entity_id: 'humidifier.classic300s'
      - delay: 2s
            entity_id: 'number.classic300s_mist_level'
  - id: luftbefeuchter_aus_mistlevel
    then:
          service: homeassistant.turn_off
setting mist_level (works)
  - platform: pid
    type: HEAT
    on_value:
      then:
        - if:
            condition:
              sensor.in_range:
                below: 0
            then:
              - lambda: |-
                  id(mist_level) = 1;
              - script.execute: luftbefeuchter_aus_mistlevel
              - logger.log:
                  format: "script: luftbefeuchter_aus_mistlevel ausführung gestartet - Mistlevel %f eingestellt"
                  args: [ 'id(mist_level)' ]
              - logger.log:
                  format: "Luftbefeuchter state: %d"
                  args: [ 'id(luftbefeuchter_zustand).state' ]
        - if:
            condition:
              sensor.in_range:
                above: 0.1
                below: 20
            then:
              - lambda: |-
                  id(mist_level) = 5;
              - script.execute: luftbefeuchter_an_mistlevel
              - logger.log:
                  format: "script: luftbefeuchter_an_mistlevel ausführung gestartet - Mistlevel %f eingestellt "
              - logger.log:
        - if:
            condition:
              sensor.in_range:
                above: 20
                below: 40
            then:
              - lambda: |-
                  id(mist_level) = 6;
              - logger.log:
                  format: "script: luftbefeuchter_an_mistlevel ausführung gestartet - Mistlevel %f eingestellt"
              - logger.log:
        - if:
            condition:
              sensor.in_range:
                above: 40
                below: 60
            then:
              - lambda: |-
                  id(mist_level) = 7;
              - logger.log:
              - logger.log:
        - if:
            condition:
              sensor.in_range:
                above: 60
                below: 80
            then:
              - lambda: |-
                  id(mist_level) = 8;
              - logger.log:
              - logger.log:
        - if:
            condition:
              sensor.in_range:
                above: 80
                below: 100
            then:
              - lambda: |-
                  id(mist_level) = 9;
              - logger.log:
              - logger.log:
     on_value:
      then:
        - lambda: |-
            id(pid_humidity_controller).target_temperature = id(RH_ZIEL).state;
        - logger.log:
            format: "Luftfeuchtigkeit = %.1f eingestellt :)"
            args: [ 'id(pid_humidity_controller).target_temperature' ]
insert global mist_level instead of ‘8’ in script works :slight_smile:
            value: !lambda return id(mist_level);
I suggest you post your complete working code for the benefit of others.
