Problem setting input_datetime using template value
Hi
I get my timestamp from an event.
The timestamp arrives in UNIX time and I have no problem converting it to local time/date (example for printing it):
message: 'Alarm clock set {{ trigger.event.data.date_time_utc_sec | int | timestamp_local }}'
However, I want to set this date & time in input_datetime object but I fail to do it
I’ve tried setting the timestamp field and the date field, both failed.
Here is how it looks now (and not working):
    - service: input_datetime.set_datetime
      entity_id: input_datetime.sagi_next_alarm_clock
      data_template:
      #timestamp: '{{ trigger.event.data.date_time_utc_sec | int }}' # not wroking
      date: '{{ strptime((trigger.event.data.date_time_utc_sec | int | timestamp_local), "%Y-%m-%d") }}' # not working either
Log error:
2018-01-15 08:24:13 ERROR (MainThread) [homeassistant.core] Invalid service data for input_datetime.set_datetime: Could not parse date for dictionary value @ data['date']. Got '2018-01-15 07:33:10'
I understand that the strptime isn’t working but I can’t figure out the correct syntax for this
Thanks !
If anyone interested, got this to work:
  data_template:
    date: >
      {% set date_time = trigger.event.data.timestamp_unix | int %}
      {{ date_time | timestamp_custom("%Y-%m-%d", true) }}
    time: >
      {{ date_time | timestamp_custom("%H:%M:%S", true) }}
This helped me a lot, but I needed to make a few changes in order to get it to work:
In my configuration.yaml I have:
input_datetime:
  sprinkler_last_runtime:
    name: Sprinkler Stored Runtime
    has_date: true
    has_time: true
And my automation.yaml has this in it:
- alias: sprinkler run time
    platform: state
    entity_id: input_boolean.sprinkler
    to: 'on'
      data_template:
        entity_id: input_datetime.sprinkler_last_runtime
        time: '{{ (as_timestamp(now()) | timestamp_custom("%H:%M:%S", true)) }}'
        date: '{{ (as_timestamp(now()) | timestamp_custom("%Y-%m-%d", true)) }}'
Thank you all for sharing, it helps a lot, but I am stuck a bit.
I am trying to create an input_number (slider) that change an input_datetime hour part. The goal is to create a nice set timer in HADashboard. My thoughts are to use the slider (range 0-23) as on hour input and another slider (range 0-59) as minute input. I have been able with the code above to set the input_datetime to current time when changing the slider, however I do not understand how to change the value of the hour setting and use the input_number as input.
#from automation.yaml
    - alias: slider_start_time
      hide_entity: false
        platform: state
        entity_id: input_number.start_hour
          data_template:
            entity_id: input_datetime.start_time
            time: '{{(states.input_number.start_hour | timestamp_custom("%H", true)}}'
            #time: '{{ (as_timestamp(now()) | timestamp_custom("%H:%M:%S", true)) }}'
And this is obviously not working. Any hints regards how to set the input_datetime.start_time hour value to the same as the input_number.start_hour?
Came a bit longer. With this code it will change, but always to 1.00 AM independent on the value of the input_number.start_hour
time: '{{ (now().time().strftime("%H") == states.input_number.start_hour) | timestamp_custom("%H:%M:%S", true) }}'
I can see that the time stamp of the input_datetime.start_hour is set to 3600, so I tried to multiply with 3600 without success =(
time: '{{ (now().time().strftime("%H") == states.input_number.start_hour) | float * 3600 | timestamp_custom("%H:%M:%S", true) }}'
With some good help and custom_component variable I solved my problem. Probably not the easiest way to solve it but anyway working fine. Here is the code.
Configuration.yaml
 input_number:
  start_hour:
    icon: mdi:timer
    initial: 19
    min: 0
    max: 23
    step: 1
  start_min:
    icon: mdi:timer
    initial: 0
    min: 0
    max: 55
    step: 5
  stop_hour:
    icon: mdi:timer
    initial: 20
    min: 0
    max: 23
    step: 1
  stop_min:
    icon: mdi:timer
    initial: 0
    min: 0
    max: 55
    step: 5
variable:
  hour_calc_start:
    value: 0
    restore: false
  min_calc_start:
    value: 0
    restore: false
  time_calc_start:
    value: 0
    restore: false
  hour_calc_stop:
    value: 0
    restore: false
  min_calc_stop:
    value: 0
    restore: false
  time_calc_stop:
    value: 0
    restore: false
input_datetime:
  start_time:
    has_date: false
    has_time: true
    initial: '19:00'
  stop_time:
    has_date: false
    has_time: true
    initial: '20:00'
Automation.yaml
  hide_entity: false
    - platform: state
    - platform: state
      entity_id: input_number.start_min
    - service: variable.set_variable
        variable: hour_calc_start
        value_template: "{{ states('input_number.start_hour') | int  * 3600 }}"
        variable: min_calc_start
        value_template: "{{ states('input_number.start_min') | int * 60 }}"
        variable: time_calc_start
        value_template: "{{((states('variable.hour_calc_start')|int) + (states('variable.min_calc_start')|int))}}"
      data_template:
        date: "{{ now().date() }}"
        time: "{{ states('variable.time_calc_start')|int|timestamp_custom('%H:%M:%S',False) }}"
- alias: slider_stop_time
  hide_entity: false
    - platform: state
      entity_id: input_number.stop_hour
    - platform: state
      entity_id: input_number.stop_min
        variable: hour_calc_stop
        value_template: "{{ states('input_number.stop_hour') | int  * 3600 }}"
        variable: min_calc_stop
        value_template: "{{ states('input_number.stop_min') | int * 60 }}"
        variable: time_calc_stop
        value_template: "{{((states('variable.hour_calc_stop')|int) + (states('variable.min_calc_stop')|int))}}"
      data_template:
        entity_id: input_datetime.stop_time
        time: "{{ states('variable.time_calc_stop')|int|timestamp_custom('%H:%M:%S',False) }}"
This worked for me:
- alias: 'Calc timer trig time'
  initial_state: 'on'
  - platform: state
    entity_id: input_number.box1, input_number.box2, input_number.box3
    data_template:
      entity_id: input_datetime.time4
      time: >
        {% set n = as_timestamp(now()) %}
        {% set b = states.input_number.box1.state|int*60*60|int+states.input_number.box2.state|int*60|int+states.input_number.box3.state|int %}
        {% set r = n+b %}
        {{ r|timestamp_custom("%H:%M:%S",True) }}
Hello i try to write the date of the day in an input_datetime.test every time an automatisation is triggered.
I try this:
  date: |
    { now() | timestamp_custom("%Y-%m-%d", true) }
entity_id: input_datetime.test
But don’t work.
Have anyone an idea why?
use data_template: , instead of data:
second to that, use double {{ }} versus the single you now use
thanks for your reply, but it don’t work.
I change it a little bit:
    entity_id: input_datetime.dernier_arrosage
    data_template:
      Date: >
        {% set n = now().strftime('%Y-%m-%d') %}
        {% set b = state('input_number.intervalle_arrosage').strftime('%d') %}
        {{% n+b %}}
input_number.intervalle_arrosage is the number of day’s between two watering.
But don’t work :unamused:
i make an step forward but i am stok again:
- id: '1597512639627'
  alias: 4 - Arrosage auto
  description: ''
  - entity_id: input_boolean.test
    platform: state
  condition: []
    data_template:
      date: >
        {{ (now().timestamp() + (state('input_number.intervalle_arrosage') * 24 * 36001)) | timestamp_custom("%Y-%m-%d", true) }}
  mode: single
without the :+ (state(‘input_number.intervalle_arrosage’)* 24 * 36001)) it give me the today date, but with it it doesn’t work.
What i want is to have the today date + the number in the input_number.intervalle_arrosage.
Can someone please help me?
