Problem Setting Up Home Assistant Connect ZBT-1as a “Thread Network”
I am trying to setup, Home Assistant Connect ZBT-1as a “Thread Network”
I am running Home Assistant on a Raspberry Pi in a docker container.
My HA instance is discovering the Home Assistant Connect ZBT-1.
Clicking Add, leads to “Pick Your Firmware”.
Then selecting : “Thread” returns this message :
Which Directs to this webpage : Home Assistant Connect ZBT-1
From there I can see that :
If you must reflash your ZBT-1 today, the following options are available:
  • For Thread: The OpenThread Border Router add-on flashes the Thread firmware on startup. You can verify the add-on logs to see the output of the firmware check or potential firmware update.
When I go to my Home Assistant installation and “Add Integration” for " Open Thread Border Router"
I am presented with the setup seen in the image below :
But unsure what to put in here? Or how to progress from here.
Please help.
I have a sneaky suspision, the problem lies with me using a docker container and I simply cannot achieve what I want to do because of the docker container… I hope this is not the case?
There must be another way to “flash the ZBT-1 for thread firmware”?
Thank you.
Your suspicion is correct.
You are following a guide that is made for HAOS, which does not work.
I know people with core haveade it work, so it is possible, but you need a guide specific for your setup.
What url do you put here? I’ve manually flashed the stick to have the Thread firmware on it. Now when I add the OpenThread Border Router integration it asks for a URL to the REST API.
Every addon I encountered for the Home Assistant OS can be just a service that runs in another docker container. What you need to do, after flashing the Home Assistant Connect ZBT-1 manually, is run the OpenThread Border Router in another docker container and put the URL that points to that docker container’s port in that text field.
There is a guide of how to create that docker container:
https://openthread.io/guides/border-router/docker/run
