Hi
I am new to Hassio/Home-Assistant. I have installed Hassio (latest version) on Ubuntu and I am trying to get it to work with a Netatmo thermostat.
My configuration.yaml has:
netatmo:
api_key: <redacted>
secret_key: <redacted>
username: <redacted>
password: <redacted>
My home-assistant.log shows:
2018-12-09 19:44:28 ERROR (MainThread) [homeassistant.setup] Error during setup of component netatmo
File "/usr/local/lib/python3.6/site-packages/homeassistant/setup.py", line 148, in _async_setup_component
component.setup, hass, processed_config) # type: ignore
File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/netatmo.py", line 53, in setup
'read_station read_camera access_camera '
File "/usr/local/lib/python3.6/site-packages/pyatmo.py", line 73, in __init__
self._accessToken = resp['access_token']
TypeError: 'NoneType' object is not subscriptable
2018-12-09 19:44:29 ERROR (MainThread) [homeassistant.components.sensor.yr] Retrying in 17 minutes: Cannot connect to host aa015h6buqvih86i1.api.met.no:443 ssl:None [Try again]
2018-12-09 19:44:32 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.159
Any ideas on how to troubleshoot this?
Thanks in advance,
Dara
