I am trying to migrate from domoticz on Raspberry to HA on Synology with docker. Installation has been tricky but solved. I am having problems with the many radiator valves (Eurotronic StellaZ) that I have and that I have been using with no major problems in domoticz. here is the issue:
I have included the device, and in the zwave configuration interface, for the corresponding node I set WAKE UP INTERVAL to 3600 (this in domoticz would tell the valve to check back to the controller every hour for getting new values). This value avoids draining the batteries with frequent reporting or polling by the controller.
Then I created a ‘radiator’ type card in the UI for the radiator Comfort setpoint (by default the valve uses this setpoint).
Here comes the problem: if I change the temp value from this interface (say from 18 to 21) the value stays for a few seconds, then changes back to the original (18). It seems the interface does not accept any new value.
Am I missing something simple since I’m new to HA?
P.S. All the above without mentioning that the ‘current temperature’ value shown in the interface is a possibly very old value but this is a separate issue solvable with frequent polling. There is a post on this)
