I’m following these instructions by Blakadder here.
I’ve added the below code to a new ESPHome device. I’ve marked the problem lines with ‘***’.
The code gives me 3 errors as follows:
Line 88: Unable to find the action with the name ‘number.decrement’.
Line 105: Unable to find the action with the name ‘number.increment’.
Line 235: [restore_mode] is an invalid option for [switch_template] did you mean [restore_state]?
Please help!
substitutions:
devicename: smart-display
matrix_pin: GPIO32
buzzer_pin: GPIO15
battery_pin: GPIO34
ldr_pin: GPIO35
left_button_pin: GPIO26
mid_button_pin: GPIO27
right_button_pin: GPIO14
scl_pin: GPIO22
sda_pin: GPIO21
external_components:
- source:
type: git
url: https://github.com/lubeda/EsphoMaTrix
refresh: 60s
components: [ ehmtx ]
esphome:
comment: "Ulanzi TC001"
on_boot:
then:
- ds1307.read_time:
esp32:
board: esp32dev
ota:
wifi:
ssid: !secret wifi_ssid
web_server:
font:
# adapt the filename to your local settings
- file: Calcium.ttf
glyphs: |
!?"%‰()+*=,-_.:°µ²³0123456789ABCDEFGHIJKLMNOPQRSTUVWXYZ abcdefghijklmnÖÄÜöäüopqrstuvwxyz€$@<>/
ehmtx:
display8x32: ehmtx_display
html: true
show_clock: 5 # duration to display the clock after this time the date is display until next "show_screen"
clock_interval: 60 # show the clock at least each x seconds
show_screen: 6 # duration to display a screen or a clock/date sequence
duration: 5 # lifetime of a screen in minutes
date_format: "%d.%m" # defaults "%d.%m." (use "%m.%d." for the US)
time_format: "%H:%M" # defaults "%H:%M" (use "%I:%M%p" for the US)
dayofweek: false # draw the day indicator on the bottom of the screen, defaults to true
show_date: true # show the date for show_screen - show_clock seconds otherwise only shows the clock for show_screen seconds, defaults to true
week_start_monday: true # default monday is first day of week, false = sunday
yoffset: 8 # the text is aligned BASELINE_LEFT, the baseline defaults to 6
xoffset: 1 # the text is aligned BASELINE_LEFT, the left defaults to 1
scroll_intervall: 80 # the interval in ms to scroll the text (default=80), should be a multiple of the update_interval from the display (default: 16ms)
anim_intervall: 192 # the interval in ms to display the next anim frame (default=192), should be a multiple of the update_interval from the display (default: 16ms)
time: ehmtx_time
font_id: ehmtx_font
icons:
- id: ha
lameid: 7956
- id: tempc
lameid: 2422
- id: plug
lameid: 403
- id: humidity
lameid: 51764
- id: co2
lameid: 30662
binary_sensor:
- platform: status
- platform: gpio
pin:
number: $left_button_pin
inverted: true
name: "$devicename left button"
on_press:
then:
- number.decrement: screen_brightness <- ***
- platform: gpio
pin:
inverted: true
number: $mid_button_pin
mode: INPUT_PULLUP
name: "$devicename middle button"
on_press:
then:
- switch.toggle: displaycontrol
- platform: gpio
pin:
number: $right_button_pin
inverted: true
name: "$devicename right button"
on_press:
then:
- number.increment: screen_brightness <- ***
# example to switch to next screen
# lambda: |-
# id(rgb8x32)->skip_screen();
logger:
level: INFO
# Enable Home Assistant API
api:
services:
- service: gauge
variables:
val: int
then:
lambda: |-
id(rgb8x32).set_gauge_value(val);
- service: alarm
variables:
icon_name: string
text: string
then:
lambda: |-
id(rgb8x32)->add_screen(icon_name,text,7,true);
id(rgb8x32)->force_screen(icon_name);
- service: screen
variables:
icon_name: string
text: string
then:
- ehmtx.add.screen:
text: !lambda return text;
icon_name: !lambda return icon_name;
alarm: false
- service: brightness
variables:
brightness: int
then:
lambda: |-
id(rgb8x32)->set_brightness(brightness);
- service: status
then:
lambda: |-
id(rgb8x32)->get_status();
- service: del_screen
variables:
icon_name: string
then:
- ehmtx.delete.screen:
- service: indicator_on
variables:
r: int
g: int
b: int
then:
- ehmtx.indicator.on:
red: !lambda return r;
green: !lambda return g;
blue: !lambda return b;
- service: force_screen
variables:
icon_name: string
then:
- ehmtx.force.screen:
- service: text_color
variables:
r: int
g: int
b: int
then:
lambda: |-
id(rgb8x32)->set_text_color(r,g,b);
- service: alarm_color
variables:
r: int
g: int
b: int
then:
lambda: |-
id(rgb8x32)->set_alarm_color(r,g,b);
- service: indicator_off
then:
- ehmtx.indicator.off:
# - service: display_on
# then:
# - ehmtx.display.on:
# id: rgb8x32
# - service: display_off
# then:
# - ehmtx.display.off:
# id: rgb8x32
- service: icons
then:
lambda: |-
id(rgb8x32)->show_all_icons();
- service: skip_screen
then:
lambda: |-
- service: tune
variables:
tune: string
then:
- rtttl.play:
rtttl: !lambda 'return tune;'
number:
name: "$devicename brightness"
min_value: 0
max_value: 255
update_interval: 1s
step: 25
lambda: |-
return id(rgb8x32)->get_brightness();
set_action:
lambda: |-
id(rgb8x32)->set_brightness(x);
switch:
icon: "mdi:power"
restore_state: ALWAYS_ON <- ***
lambda: |-
return id(rgb8x32)->show_display;
turn_on_action:
lambda: |-
id(rgb8x32)->set_display_on();
turn_off_action:
lambda: |-
id(rgb8x32)->set_display_off();
- platform: sht3xd
temperature:
name: "$devicename Temperature"
humidity:
name: "$devicename Humidity"
update_interval: 60s
- platform: adc
pin: $battery_pin
update_interval: 10s
device_class: battery
accuracy_decimals: 0
attenuation: auto
filters:
- sliding_window_moving_average:
window_size: 15
send_every: 15
send_first_at: 1
- multiply: 1.6
- lambda: |-
return ((x - 3) / 0.69 * 100.00);
unit_of_measurement: '%'
- platform: adc
name: "$devicename Illuminance"
pin: $ldr_pin
attenuation: auto
unit_of_measurement: lx
filters:
- lambda: |-
return (x / 10000.0) * 2000000.0 - 15 ;
output:
- platform: ledc
pin: $buzzer_pin
rtttl:
output: rtttl_out
i2c:
sda: 21
scl: 22
scan: true
light:
- platform: neopixelbus
type: GRB
variant: WS2812
pin: $matrix_pin
num_leds: 256
color_correct: [30%, 30%, 30%]
restore_mode: ALWAYS_OFF
on_turn_on:
lambda: |-
id(ehmtx_display)->set_enabled(false);
on_turn_off:
lambda: |-
id(ehmtx_display)->set_enabled(true);
time:
- platform: homeassistant
on_time_sync:
then:
ds1307.write_time:
- platform: ds1307
update_interval: never
display:
- platform: addressable_light
addressable_light_id: ehmtx_light
width: 32
height: 8
pixel_mapper: |-
if (y % 2 == 0) {
return (y * 32) + x;
return (y * 32) + (31 - x);
rotation: 0°
update_interval: 16ms
auto_clear_enabled: true
lambda: |-
id(rgb8x32)->tick();
id(rgb8x32)->draw();
