Problem setting up Xiaomi Wireless Double Key
I have the Xiaomi Gateway, Double Key switch and a Wireless Double Key switch. So far the integration for the gateway and Wired Double Key switch has been fantastic. Gateway is easy to set up and everything else is automatically detected.
Except the Wireless Double key switch… It works fine with the Mi Home app and I can set up automation through that but I cannot seem to get home assistant to recognise it as a binary sensor… It just does not show up in the states or services as an entity. Where others have succeeded on tutorials I have followed… mine seems to fail.
I cannot find anything online as to why this is happening, hens the cry for help! hopefully it is a fairly simple fix?
Thanks!
