I set up using Z-wave js no problem. It only takes a second to negotiate and then the node is visible.
I reverted to a back up before i installed z-wave js and tried to set up z-wave js ui and it is not allowing me to add my ring keypad.
I install z-wave js ui and add my controller without an issue
It failed the interview. How far from the coordinator is it? Ping the node and re-interview… If it continues grab a debug log while you’re running the include.
Its right next to it. About 5 ft.
Z-wave js UI hangs and will not allow me to do anything else after it starts that process. The CPU usage for the add-on shows over 50% while its hung.
I just stopped the add on and started it again. it goes back to the last state of hung and high cpu usage.
