I installed the speed test sensor component correctly but keep getting “unknown” as values for Ping, Download and Upload speeds.
What I did was the following.
I have installed speedtest-click 0.3.4 on my Raspberry which runs the latest HASS 0.13.0 update.
From the command line I did a “speedtest-cli --simple” to confirm it working.
I found that HASS was looking for speedtest_click.py in /var/opt/homeassistant/lib/ while this file is installed in /usr/local/lib/python3.4/dist-packages/
A cp /usr/local/lib/python3.4/dist-packages/speedtest_cli.py /var/opt/homeassistant/lib/ solved my issue.
Is the speedtest reliable?
The test done from the HASS speedtest interface on my RPI with ethernet connection is much less than I can get from my phone with wireless connection.
I’ve 60Mbit/s up and down speed on my line, speedtest on HASS shown around 8Mbit/s down and 6Mbit/s up speed.
If I run the test at speedtest webpage from my phone or tablet I get close to 60Mbit/s as my line is.
benchmarks on all the interfaces and found the following results:
[color=#0040BF]•Internal LAN (10/100): 94.4 Mbits/sec (11.8 MB/sec)
•USB 802.11n WiFi: 44.5 Mbits/sec (5.6 MB/sec)
•USB Gigabit LAN (10/100/1000): 222 Mbits/sec (27.8 MB/sec)[/color]
I did this and worked for me. Make sure you set the GPU memory to 16 (minimum.)
Thank you for your reply!
I will look more into it details.
As I can see from the first link that B+ version of RPI does have a lover ethernet speed than RPI 2, I’m using B+ so that might be the thing.
Mainly I don’t think there is any problem, then the speedtest is at the moment useless for me since my RPI does the limitation, it is just nice to log it since HASS had the feature.
It is strange that I’m also using a RPI B+ for media center running kodi, but I don’t have any problems with streaming 1080P movies with 5.1 sorround from my NAS over ehternet.
subprocess.CalledProcessError: Command '['/usr/bin/python3', '/usr/local/lib/python3.4/dist-packages/speedtest_cli-0.3.4-py3.4.egg/speedtest_cli.py', '--simple']' returned non-zero exit status 1
