Hi all,
I am having an issue with templating and am looking to get some advice. Hopefully its something small that I have overlooked and any input would be appreciated.
I am looking to create a rest binary sensor for my doorbell to determine what a particular setting is set to and almost have it figured out. I am having issues with templating an if-then statement. My current configuration that I have confirmed as working is here:
binary_sensor:
- platform: rest
scan_interval: 10
resource: Doorbell HTTP Address
username: !secret
password: !secret
authentication: digest
device_class: problem
value_template: "{{ value.split('=')[-1] }}"
With the value template configured this way the result is a string that is correctly either “true” or “false” depending on what the doorbell setting is currently set to. However, I need to invert this so that if the setting is set to “true” the output of the value template needs to be a string that says “false”. Here is my attempt at a configuration for that scenario:
binary_sensor:
- platform: rest
scan_interval: 10
username: !secret
password: !secret
value_template: >
{% if value.split('=')[-1] == 'false' %}
true
{% else %}
false
{% endif %}
The output of this configuration is always “false” no matter what the setting I am monitoring is set to. I feel like this should be a pretty straight forward task, but I am pretty unfamiliar with templating (hoping to get better) and I just can’t figure this one out. I feel like it is something simple that I am overlooking. I would greatly appreciate any input. Thanks.
