Problem this morning
Hi, some weeks my esp Temp controller runs perfect , but now i can t get the temperatures.
shut down all and restart HA
but the same problem
update 3 days ago
Logger: homeassistant.components.sensor
Quelle: helpers/entity_platform.py:719
Integration: Sensor ([Dokumentation](https://www.home-assistant.io/integrations/sensor), [Probleme](https://github.com/home-assistant/core/issues?q=is%3Aissue+is%3Aopen+label%3A%22integration%3A+sensor%22))
Erstmals aufgetreten: 07:27:11 (8 Vorkommnisse)
Zuletzt protokolliert: 07:27:11
* Platform esphome does not generate unique IDs. ID D4:8A:FC:C7:BD:FC-sensor-temp_ruecklauf_hk already exists - ignoring sensor.temp_ruecklauf_hk
* Platform esphome does not generate unique IDs. ID D4:8A:FC:C7:BD:FC-sensor-temp_vorlauf_solar already exists - ignoring sensor.temp_vorlauf_solar
* Platform esphome does not generate unique IDs. ID D4:8A:FC:C7:BD:FC-sensor-temp_ruecklauf_solar already exists - ignoring sensor.temp_ruecklauf_solar
* Platform esphome does not generate unique IDs. ID D4:8A:FC:C7:BD:FC-sensor-temp_speicher_oben already exists - ignoring sensor.temp_speicher_oben
* Platform esphome does not generate unique IDs. ID D4:8A:FC:C7:BD:FC-sensor-temp_speicher_unten already exists - ignoring sensor.temp_speicher_unten
Solved
Sorry
one point at the breadboard was removed
don t know how it could happen
now all ok again
