Hello together,
I’m new to Home Assistant and have problems to integrate “Devolo Home Control”
My configuration is:
Version core-2022.2.2
Installationstyp Home Assistant Container on Synology DS218+
Entwicklung false
Supervisor false
Docker true
Benutzer root
Virtuelle Umgebung false
Python-Version 3.9.7
Betriebssystemfamilie Linux
Betriebssystem-Version 4.4.180+
CPU-Architektur x86_64
Zeitzone UTC
When I try to integrate Devolo Home Control
I have to enter my eMail address and password,
the field “My Devolo URL” is already preset with “https://www.mydevolo.com”
After hitting the send button I receive the message “Success - Configuration for
Devolo Home Control is created” and a “Done” button.
When I click the button the integration is shown but with an error message “error during setup - check the protocols”
The log show following stack trace:
Logger: homeassistant.config_entries
Source: components/devolo_home_control/init.py:53
First occurred: 15:10:58 (5 occurrences)
Last logged: 23:05:39
Error setting up entry devolo Home Control for devolo_home_control
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 327, in async_setup
result = await component.async_setup_entry(hass, self)
File "/usr/src/homeassistant/homeassistant/components/devolo_home_control/__init__.py", line 53, in async_setup_entry
await hass.async_add_executor_job(
File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 52, in run
File "/usr/local/lib/python3.9/site-packages/devolo_home_control_api/homecontrol.py", line 52, in __init__
self._inspect_devices(self.get_all_devices())
File "/usr/local/lib/python3.9/site-packages/devolo_home_control_api/homecontrol.py", line 220, in _inspect_devices
getattr(self, message_type)(uid_info)
File "/usr/local/lib/python3.9/site-packages/devolo_home_control_api/homecontrol.py", line 164, in _general_device
self.devices[device_uid].settings_property['general_device_settings'] = SettingsProperty(
File "/usr/local/lib/python3.9/site-packages/devolo_home_control_api/properties/settings_property.py", line 43, in __init__
self.zone = kwargs.pop("zones")[kwargs['zone_id']]
KeyError: 'default_hz'
Can someone please tell me what the problem is?
Any help is appreciated.
Thank you
Markus
