Problem to update zwave.js to 0.1.49
Does no one check existing issues anymore ?
You’ll find that I did and updated the post accordingly to let others know. Check the gun before you fire.
Sorry, I was not talking to you, you did.
In fairness, I still should have checked the issues before trying to update, but I’m just too impatient as I suspect most are.
Same issue here
same issue here
Same issue here
same issue here across 4 HA units
This is now working and is installed? Last night did the upgrade and it failed. Went to bed and just went back to see if there is a fix and it is magically installed and working??? 0.1.49 is installed???
