Perfect! Last version is installed successfully (0.63.3)
But when I go to ‘info’ in the web UI, it still says 0.45.1 (the initial version installed in my Raspberry Pi)
Is there a method to upgrade the Web UI? I’ve been searching about this a long time, but it seems nobody have the same problem.
Check if you have more than one version running, ps -aux then try rebooting maybe, also did you originally install to a virtual env?, if so you need to be in the virtual env to properly upgrade.
Ohhh ok, you found the problem, no, I didnt install to a virtual env, I made a few tries, but I was stuck in a step, so I install it on ‘pi’…
Maybe thats the problem… Someday I will make a new clean installation in a virtual env, as it suposes to be.
