Problem upgrading hassio from 0.99.3 to 0.100.2
Hi.
I’am getting an error message trying to upgrade Hassio running in vmware from 0.99.3 -> 0.100.2.
Upgrades before has been without issue.
Log:
9-10-16 17:50:00 INFO (MainThread) [hassio.homeassistant] Update Home Assistant to version 0.100.2
19-10-16 17:50:00 INFO (SyncWorker_5) [hassio.docker.interface] Update image homeassistant/qemux86-64-homeassistant:0.99.3 to homeassistant/qemux86-64-homeassistant:0.100.2
19-10-16 17:50:00 INFO (SyncWorker_5) [hassio.docker.interface] Pull image homeassistant/qemux86-64-homeassistant tag 0.100.2.
19-10-16 17:51:13 ERROR (SyncWorker_5) [hassio.docker.interface] Can’t install homeassistant/qemux86-64-homeassistant:0.100.2 -> 404 Client Error: Not Found (“no such image: homeassistant/qemux86-64-homeassistant:0.100.2: No such image: homeassistant/qemux86-64-homeassistant:0.100.2”).
19-10-16 17:51:13 WARNING (MainThread) [hassio.homeassistant] Update Home Assistant image fails
Same for me but with hassio running in proxmox.
Dont really know where to start :thinking:
Same problem here. Running Hassio as VM on Hyper-V.
Same here, any luck anyone?
I am also facing upgrade issue from 0.98.5 to 0.100.2. I used Hass.io GUI in front end and post upgrade OS started, SSH and Samba working but HA front end not coming up. Rolled back to 0.98.5, everything works fine. There was no error message in HA log, only warnings for custom Alexa, Hue and Sony Bravia. Any idea what could be causing front end/Lovelace not to load? All my old automation rules, config are in manually created yaml files.
Facing exactly the same issue trying to upgrade from 0.98.4 to 0.100.2. Has anyone been successful with the upgrade so far?
Was running hass.io 98.2 on Ubuntu 18.04.3 and successfully upgraded to 100.2. The UI is loading fine for me. Let me know if I can help.
I have the same problem updating from 0.99.2. to 0.100.2 :frowning:
Anyone figure this out?
Hi. For me the problem went away when uninstalled the addon: Check Home Assistant configuration from the addon store.
After uninstallation. Home Assistant upgraded and everything seems fine.
