Osirys
(Osirys)
1
Hello I installed go2rtc and I configured my cameras with the bubble option
streams:
camera1: bubble://admin:[email protected]:80/bubble/live?ch=0&stream=0
then create a card with webrtc and it works very well
type: custom:webrtc-camera
url: rtsp://localhost:8554/camera1
I would now like to switch to frigate and I know that go2rtc is on board with it.
So I disabled go2rtc and installed frigate
In frigate.yml, here is my config
mqtt:
enabled: False
go2rtc:
streams:
camera1:
- bubble://admin:[email protected]:80/bubble/live?ch=0&stream=0
cameras:
back:
ffmpeg:
inputs:
- path: rtsp://127.0.0.1:8554/camera1
roles:
- detect
detect:
width: 1280
height: 720
when I am in the frigate interface I have no image from my camera.
Can you tell me what I’m not doing correctly?
Thanks a lot
Osirys
(Osirys)
3
I don’t understand, am I using the same configuration for the camera with the bubble?
ddaniel
(Daniel Dekovic)
4
No, my mistake, sorry.
This is what I have in my config
go2rtc:
streams:
doorbell:
- ffmpeg:rtsp://server:8554/doorbell?video=h264&audio=all
cameras:
- path: rtsp://xx:[email protected]:554/Streaming/Channels/101/
Osirys
(Osirys)
5
In the logs when starting frigate I see that I have an error
2023-10-25 21:30:02.419811761 23:30:02.419 ERR github.com/AlexxIT/go2rtc/cmd/streams/producer.go:53 > error=“unsupported scheme: bubble://admin:[email protected]. 1.49:80/bubble/live?ch=0&stream=0” url=bubble://admin:[email protected]:80/bubble/live?ch=0&stream=0
For go2rtc is well on board and therefore bubble should be recognized right?
crzynik
(Nicolas Mowen)
6
you need to update the internal version of go2rtc to the latest Advanced Options | Frigate
Osirys
(Osirys)
7
OK I understand.
So I’m going to need your help ![:slight_smile: :slight_smile:](https://community.home-assistant.io/images/emoji/twitter/slight_smile.png?v=10)
I saw the following note
So I was here
and I downloaded the zip. I unzipped and I have a go2rtc-master folder which I rename to go2rtc
Is this the folder I need to copy and paste into the config folder?
How do I give go2rtc execution permission?
Thank you for your help
crzynik
(Nicolas Mowen)
8
you should not be downloading the zip, you should download the release specifically from the releases page
