Still a bit green with HA. I’m trying to start using the new template when creating sensors but I’m running into a brick wall:
As an aside, i have created this sensor using the old templating method and it works, I wanted to add attributes but couldn’t, that was why I’m changing to the new method.
I created a new template_sensors.yaml file and included it in my config.yaml using “template: !include template_sensors.yaml”
inside the template_sensors yaml file I have the following code:
template:
- sensor:
- name: Public power Available
unit_of_measurement: "Presently"
state: >
{% if states('binary_sensor.elec_indoors_contact') == 'off' %}
{%set p_stat = "Grid Not Available"%}
{% else %}
{%set p_stat = "Grid Available" %}
{% endif %}
{{p_stat}}
attribute_template:
time_since_last_change: >
{{ (as_timestamp(now()) - as_timestamp(states.binary_sensor.elec_indoors_contact.last_changed)) | timestamp_custom("%H:%M:%S", false) }}
However, it doesn’t load when I try to restart all template entities in developer tools, I get the following error:
Logger: homeassistant.config
Source: config.py:868
First occurred: 12:59:34 PM (1 occurrences)
Last logged: 12:59:34 PM
Invalid config for [template]: [template] is an invalid option for [template]. Check: template->template. (See /config/template_sensors.yaml, line 1).
I’ve read all the topics I could find on here but wasn’t able to solve this issue. would appreciate any assistance.
