Hello, I’m trying to create an assistant on an M5Stack Atom Echo capable of being used outside of my home network, to put it inside a The Mandalorian helmet that I’m building.
For this I thought of using this code:
esphome:
friendly_name: M5StackAtomEcho Assist
name_add_mac_suffix: true
project:
version: "1.0"
min_version: 2024.2.0
esp32:
board: m5stack-atom
framework:
type: esp-idf
logger:
api:
encryption:
key: "*****"
ota:
password: "*****"
dashboard_import:
package_import_url: github://esphome/firmware/voice-assistant/m5stack-atom-echo.yaml@main
wifi:
output_power: 18
on_connect:
- delay: 5s # Gives time for improv results to be transmitted
- ble.disable:
on_disconnect:
- ble.enable:
ssid: "*****"
password: "*****"
# Optional manual IP
#manual_ip:
# static_ip: 192.168.1.30
# gateway: 192.168.1.1
# subnet: 255.255.255.0
improv_serial:
esp32_improv:
authorizer: none
button:
- platform: factory_reset
i2s_audio:
i2s_lrclk_pin: GPIO33
i2s_bclk_pin: GPIO19
microphone:
- platform: i2s_audio
i2s_din_pin: GPIO23
adc_type: external
pdm: true
speaker:
i2s_dout_pin: GPIO22
dac_type: external
mode: mono
voice_assistant:
microphone: echo_microphone
speaker: echo_speaker
noise_suppression_level: 2
auto_gain: 31dBFS
volume_multiplier: 2.0
vad_threshold: 3
on_listening:
- light.turn_on:
blue: 100%
red: 0%
green: 0%
effect: "Slow Pulse"
on_stt_vad_end:
- light.turn_on:
blue: 100%
red: 0%
green: 0%
effect: "Fast Pulse"
on_tts_start:
- light.turn_on:
blue: 100%
red: 0%
green: 0%
brightness: 100%
effect: none
on_tts_end:
- homeassistant.service:
service: media_player.play_media
entity_id: media_player.wohnzimmer #add your media player here
media_content_id: !lambda 'return x;'
media_content_type: music
announce: "true"
on_end:
- delay: 100ms
- wait_until:
not:
speaker.is_playing:
- script.execute: reset_led
on_error:
- light.turn_on:
red: 100%
green: 0%
blue: 0%
brightness: 100%
effect: none
- delay: 1s
on_client_connected:
- if:
condition:
switch.is_on: use_wake_word
then:
- voice_assistant.start_continuous:
on_client_disconnected:
- if:
condition:
then:
- voice_assistant.stop:
- light.turn_off: led
binary_sensor:
- platform: gpio
pin:
number: GPIO39
inverted: true
disabled_by_default: true
entity_category: diagnostic
on_multi_click:
- timing:
- ON for at least 250ms
- OFF for at least 50ms
then:
- if:
condition:
switch.is_off: use_wake_word
then:
- if:
condition: voice_assistant.is_running
then:
else:
- voice_assistant.start:
else:
- delay: 1s
- script.wait: reset_led
- timing:
- ON for at least 10s
then:
- button.press: factory_reset_btn
light:
- platform: esp32_rmt_led_strip
entity_category: config
pin: GPIO27
default_transition_length: 0s
chipset: SK6812
num_leds: 1
rgb_order: grb
rmt_channel: 0
effects:
- pulse:
transition_length: 250ms
update_interval: 250ms
min_brightness: 50%
max_brightness: 100%
- pulse:
transition_length: 100ms
update_interval: 100ms
min_brightness: 50%
script:
- id: reset_led
then:
- if:
condition:
- switch.is_on: use_wake_word
- switch.is_on: use_listen_light
then:
- light.turn_on:
red: 100%
green: 89%
blue: 71%
brightness: 60%
effect: none
else:
switch:
name: Use wake word
optimistic: true
restore_mode: RESTORE_DEFAULT_ON
on_turn_on:
- lambda: id(va).set_use_wake_word(true);
- if:
condition:
not:
- voice_assistant.is_running
then:
on_turn_off:
- lambda: id(va).set_use_wake_word(false);
name: Use listen light
optimistic: true
on_turn_on:
on_turn_off:
external_components:
- source: github://pr#5230
components:
- esp_adf
refresh: 0s
esp_adf:
taken from this page, only edited changing the api to mqtt:
https://community.home-assistant.io/t/a-silly-simple-question-about-esphome-specifically-m5stack-atom-echo-firmware/674850/5
My problem is that, when loading the code, I get this:
and this:
Window, after that I get this error:
========================= [SUCCESS] Took 58.04 seconds =========================
INFO Successfully compiled program.
INFO Connecting to 172.16.2.26
INFO Uploading /data/build/m5stackatomecho_assist-30592c/.pioenvs/m5stackatomecho_assist-30592c/firmware.bin (1606720 bytes)
ERROR ESP requests password, but no password given!
and if I go inside the .yalm file that it created for me, it looks nothing like the original:
substitutions:
friendly_name: GE00_M5StackAtomEcho
packages:
m5stack.atom-echo-voice-assistant: github://esphome/firmware/voice-assistant/m5stack-atom-echo.yaml@main
esphome:
name_add_mac_suffix: false
friendly_name: ${friendly_name}
api:
encryption:
key: *****
wifi:
ssid: !secret wifi_ssid
I emphasize that I have not yet tried integrating it with mqtt, first I want to see if I can get an editable code to be able to play with it
Can anyone give me any ideas?
