I have a problem to control my 8 relays board whit my 74HC595, esp32 nodemcu-32s and ESPHome.
It turning on … but the turn off only after I toggle the switch 3-4 times
OE pin on Low
I have a capacitor between the + an -
All on 5 volts
sn74hc595:
- id: 'sn74hc595_hub'
data_pin: GPIO14
clock_pin: GPIO12
latch_pin: GPIO04
# Individual outputs
switch:
- platform: gpio
pin:
sn74hc595: sn74hc595_hub
# Use pin number 0
number: 0
inverted: true
- platform: gpio
pin:
# Use pin number 1
number: 1
inverted: true
- platform: gpio
pin:
# Use pin number 2
number: 2
inverted: true
- platform: gpio
pin:
# Use pin number 3
number: 3
inverted: true
- platform: gpio
pin:
# Use pin number 4
number: 4
inverted: true
