Thanks for your response.
As a hobby, I spend a lot of time doing HA and try out a lot of things.
This is a big Macro. If there is an error somewhere in the maro’s, it should simply be ignored! I don’t know how I would do this.
Might not look as good with wouldn’t know how else to do this at this point!
This is part of the script!
alias: Berichten
sequence:
- service: script.kies_output
Welke_Pauze: 2
Welke_Output: "{{Welke_Output}}"
Titel: "{{Titel}}"
Extra_Volume: "{{Extra_Volume}}"
Geluid: >-
{% macro Melding() %}
{% if is_state("input_select.geluid_biepen", "Geen") %}
'Biep 1', 'Biep 2', 'Biep 3', 'Biep 4', 'Biep 5', 'Biep 6', 'Biep 7', 'Biep 8', 'Biep 9', 'Biep 10', 'Biep 11', 'Biep 12', 'Biep 13', 'Biep 14', 'Biep 15', 'Biep 16', 'Biep 17',
'Biep 18', 'Biep 19', 'Biep 20', 'Biep 21', 'Biep 22', 'Biep 23', 'Biep 24', 'Biep 25', 'Biep 26', 'Biep 28', 'Biep 29', 'Biep 30', 'Biep 31', 'Biep 32', 'Biep 33','Biep 34', 'DingDong'
] | random }}
{% else %}
{{states("input_select.geluid_biepen")}}
{% endif %}
{% endmacro %}
{# a macro that removes all newline characters, empty spaces, and
returns formatted text. Also replaces all Underscores with Spaces #}
{%- macro cleanup(data) -%}
{%- for item in data.split("\n") if item | trim != "" -%}
{{ item | trim | replace("_", " ") }} {% endfor -%}
{%- endmacro -%}
{# ******** Start the Speech routines ******** #}
{# a macro to call all macros :) #}
{%- macro mother_of_all_macros() -%}
{% if call_Melding == 1 %}
{{ Melding() }}
{% endif %}
{%- endmacro -%}
{{- cleanup(mother_of_all_macros()) -}}
Tekst: |-
{% macro Weerbericht() %}
Op dit moment in Maaseik is het
{{states.sensor.buienradar_temperature.state.split(".")[0]}} komma {{states.sensor.buienradar_temperature.state.split(".")[1]}} Graden.
De gevoelstemperatuur is
{% if states.sensor.buienradar_temperature.state == states.sensor.buienradar_feel_temperature.state %}
ook
{% else %}
er echter
{% endif %}
{{states.sensor.buienradar_feel_temperature.state.split(".")[0]}} komma {{states.sensor.buienradar_feel_temperature.state.split(".")[1]}} .
{% if states.sensor.buienradar_temperature.state | int <= -3 %}
'Het is zeer koud en het vriest.',
'Het is zeer koud en het vriest, let op als je met de auto weg gaat, het kan glad zijn.',
] | random }}
{% elif states.sensor.buienradar_temperature.state | int <= 5 %}
'Het is zeer koud maar het zal niet vriezen vandaag.',
] | random }}
{% elif states.sensor.buienradar_temperature.state | int <= 12 %}
'Het is zeer fris, ik zou zeker een jas meenemen als je buiten gaat.',
'Het is zeer fris, een jas is zeker nodig.',
] | random }}
{% elif states.sensor.buienradar_temperature.state | int <= 18 %}
'Het is best fris, Je kunt best een jasje gebruiken.',
'Het is best fris, een jas is geen overbodige luxe.',
] | random }}
{% elif states.sensor.buienradar_temperature.state | int <= 24 %}
'Het is een redelijke tempratuur, maar een jas is niet echt nodig.',
] | random }}
{% elif states.sensor.buienradar_temperature.state | int <= 30 %}
'Het is warm, je hebt echt geen jas nodig.',
'Het is warm, het is echt weer voor een terrasje.',
] | random }}
{% else %}
'Het is heet, tijd om je te verfrissen.',
'Het is heet, ideaal voor een terrasje te pikken.',
] | random }}
{% endif %}
De maximum Temperatuur van vandaag is {{states('sensor.buienradar_temperature_1d').split('.')[0]}}
komma {{states('sensor.buienradar_temperature_1d').split('.')[1]}}.
{% if states.sensor.openweathermap_forecast_temperature_low.state != "unknown" %}
en het minimum is {{states.sensor.openweathermap_forecast_temperature_low.state.split(".")[0]}}
komma {{states.sensor.openweathermap_forecast_temperature_low.state.split(".")[1]}}
{% endif %}
Er is een
{% if states.sensor.buienradar_wind_force.state | int <= 15 %}
lichte
{% elif states.sensor.buienradar_wind_force.state | int > 15 and
states.sensor.buienradar_wind_force.state | int <= 25 %}
matige
{% else %}
harde
{% endif %} wind die komt vanuit het
{% if states.sensor.buienradar_wind_direction.state == "N" %}
Noorden
{% elif states.sensor.buienradar_wind_direction.state == "NNO" %}
Noord-Noord-Oosten
{% elif states.sensor.buienradar_wind_direction.state == "NO" %}
Noord-Oosten
{% elif states.sensor.buienradar_wind_direction.state == "O" %}
Oosten
{% elif states.sensor.buienradar_wind_direction.state == "ZO" %}
Zuid-Oosten
Noord-Noord-Oosten
Noord-Oosten
Oosten
{% elif states.sensor.buienradar_wind_direction.state == "OZO" %}
Oost-Zuid-Oosten
{% elif states.sensor.buienradar_wind_direction.state == "ONO" %}
Oost-Noord-Oosten
Zuid-Oosten
{% elif states.sensor.buienradar_wind_direction.state == "ZZO" %}
Zuid-Zuid-Oosten
{% elif states.sensor.buienradar_wind_direction.state == "Z" %}
Zuiden
{% elif states.sensor.buienradar_wind_direction.state == "ZZW" %}
Zuid-Zuid-Westen
{% elif states.sensor.buienradar_wind_direction.state == "ZW" %}
Zuid-Westen
{% elif states.sensor.buienradar_wind_direction.state == "WZW" %}
West-Zuid-Westen
{% elif states.sensor.buienradar_wind_direction.state == "W" %}
Westen
{% elif states.sensor.buienradar_wind_direction.state == "WNW" %}
West-Noord-Westen
{% elif states.sensor.buienradar_wind_direction.state == "NW" %}
Noord-Westen
{% elif states.sensor.buienradar_wind_direction.state == "NNW" %}
Noord-Noord-Westen
{% endif %}
met een kracht van {{states.sensor.buienradar_wind_speed.state.split(".")[0] }} Komma {{states.sensor.buienradar_wind_speed.state.split(".")[1]}}
Kilometer per uur.
op dit moment is
{% if states.sensor.openweathermap_weather.state == "onbewolkt" or
states.sensor.openweathermap_weather.state == "licht bewolkt" or
states.sensor.openweathermap_weather.state == "bewolkt" or
states.sensor.openweathermap_weather.state == "half bewolkt"%}
{% set voor = "het" %}
{% else %}
{% set voor = "er" %}
{% endif %}
{{voor}} {{states.sensor.openweathermap_weather.state}}
en het
{% if states.sensor.buienradar_rain_last_hour.state | int == 0 %}
'is droog,',
] | random }}
{% elif states.sensor.buienradar_rain_last_hour.state | int <= 20 %}
' regend een beetje,',
] | random }}
{% elif states.sensor.buienradar_rain_last_hour.state | int <= 40 %}
' regend,',
] | random }}
{% elif states.sensor.buienradar_rain_last_hour.state | int <= 50 %}
' regend redelijk hard,',
] | random }}
{% elif states.sensor.buienradar_rain_last_hour.state | int > 50 %}
' regend pijpenstelen,',
] | random }}
{% endif %}
{% if states.sensor.openweathermap_forecast_precipitation_probability.state | int == 0.0 %}
en
{% else %}
maar
{% endif %}
'er is geen regen voorspelt.',
] | random }}
{% elif states.sensor.openweathermap_forecast_precipitation_probability.state | int <= 5%}
'er is zeer weinig kans op regen.',
] | random }}
{% elif states.sensor.openweathermap_forecast_precipitation_probability.state | int <= 10%}
'er is een zeer kleine kans op regen.',
] | random }}
{% elif states.sensor.openweathermap_forecast_precipitation_probability.state | int <= 20 %}
'er is een heel kleine kans op regen.',
] | random }}
{% elif states.sensor.openweathermap_forecast_precipitation_probability.state | int <= 30 %}
'er is een matige kans op regen.',
] | random }}
{% elif states.sensor.openweathermap_forecast_precipitation_probability.state | int <= 40 %}
'er is kans op regen.',
] | random }}
{% elif states.sensor.openweathermap_forecast_precipitation_probability.state | int <= 50 %}
'er is een redelijk grote kans op regen.',
] | random }}
{% elif states.sensor.openweathermap_forecast_precipitation_probability.state | int <= 60 %}
'er is een grote kans op regen.',
] | random }}
{% elif states.sensor.openweathermap_forecast_precipitation_probability.state | int <= 70 %}
'er is een zeer grote kans op regen.',
] | random }}
{% else %}
'het gaat vandaag zeker regenen. Ik zou een paraplu bij de hand houden.',
] | random }}
{% endif %}
{% else %}
Zijnde
{{states.sensor.openweathermap_forecast_precipitation_probability.state}} Procent
en er zal waarschijnlijk {{states.sensor.openweathermap_forecast_precipitation.state.split(".")[0]}} Komma
{{states.sensor.openweathermap_forecast_precipitation.state.split(".")[-1]}} milimeter neerslag vallen.
{% endif %}
Er is een Luchtvochtigheid van {{states.sensor.openweathermap_humidity.state}} Procent.
{% endmacro %}
{% macro Taken() %}
{%- set huw = namespace(data = []) %}
{% set taak = namespace(data = []) %}
{% set taakmorg = namespace(data = []) %}
{% set taakoverm = namespace(data = []) %}
{% set verg = namespace(data = []) %}
{% set verj = namespace(data = []) %}
{% for i in range(0, states.sensor.agenda_bart.state|int) %}
{% if state_attr("ensor.agenda_bart",
"data")[i].startDateISO.split("T")[0]
== (now().date() + timedelta(days= 0))|string %}
{% if state_attr("sensor.agenda_bart", "data")[i].summary.split(" ")[0]|title
== "Verjaardag"|title %}
{%- set verj.data = verj.data +
[{'vn': state_attr("sensor.agenda_bart", "data")[i].summary.split(" ")[1],
'an': state_attr("sensor.agenda_bart", "data")[i].summary.split(" ")[2],
'jr': state_attr("sensor.agenda_bart", "data")[i].summary.split(" ")[-1]}] %}
{% elif state_attr("sensor.agenda_bart", "data")[i].summary.split(" ")[0]|title
== "Vergadering"|title %}
{%- set verg.data = verg.data +
[{'wie': state_attr("sensor.agenda_bart", "data")[i].summary.split(" ")[1:]|join(" "),
'uur': state_attr("sensor.agenda_bart", "data")[i].startTime,
'bij': state_attr("sensor.agenda_bart", "data")[i].location}] %}
== "Huwelijksverjaardag"|title %}
{%- set huw.data = huw.data +
[{'wie': state_attr("sensor.agenda_bart", "data")[i].summary.split(" ")[1:-1]|join(" "),
{% else %} {%- set taak.data = taak.data +
[{'wat': state_attr("sensor.agenda_bart", "data")[i].summary,
'bij': state_attr("sensor.agenda_bart", "data")[i].location,
'uur': state_attr("sensor.agenda_bart", "data")[i].startTime}] %}
{% endif -%} {% elif (state_attr("sensor.agenda_bart",
"data")[i].startDateISO.split("T")[0].split("-")[1:]|join)|int
-(now().strftime("%m%d"))|int == 1 %}
{%- set taakmorg.data = taakmorg.data +
{% endif -%} {% endfor -%}
{%- if verj.data|count != 0 %}
{% if verj.data|count == 1 %}
{%- set ww = "is" %}
{%- set pers = "persoon" %}
{%- else %} {%- set ww = "zijn" %} {%- set pers = "personen" -%}
{% endif -%}
'vandaag ' + ww + " " + verj.data|count|string + " " + pers + ' die je kent Jarig',
'vandaag ' + ww + " " + verj.data|count|string + " " + pers + ' uit je contacten Jarig',
'je hebt vandaag ' + verj.data|count|string + ' jarige in je contacten',
] | random }}
zijnde: ,
{% for i in range(0, verj.data|count) %}
{{ verj.data[i].vn }} {{verj.data[i].an}}
{{-" "-}}wordt
{%- if verj.data[i].jr|int| default(false) -%}
{{" "}}{{-now().strftime("%Y")|int - verj.data[i].jr|int-}}
{% endif -%}
{{" "-}}jaar.
{%- if i + 2 == verj.data|count -%}
{{" "-}}en
{%- elif i + 2 < verj.data|count -%}
{% endif %}
{% endfor %}
{% endif %}
{%- if verg.data|count != 0 %} {% if verg.data|count == 1 %}
{%- set ww = "vergadering" -%}
{%- set vv = "een" -%}
{%- else -%}
{%- set ww = "vergaderingen" -%}
{%- set vv = verg.data|count|string -%}
{%- endif -%}
'Je Hebt vandaag ' + vv + ' ' + ww,
'vandaag Heb je ' + vv + ' ' + ww,
] | random }}
zijnde: ,
{% for i in range(0, verg.data|count) %}
met {{ verg.data[i].wie }} om,{{ verg.data[i].uur }} uur
{% if verg.data[i].bij| default(false) %}
{% if verg.data[i].bij|title == "Thuis" %}
{% elif verg.data[i].bij|title == "Ziekenhuis" %}
,in het
{% else %}
bij
{% endif %}
{{ verg.data[i].bij }}
{%- endif -%}
{%- if i + 2 == verg.data|count -%}
{{" "-}}en
{%- elif i + 2 < verg.data|count -%}
{% endif %}
{% endfor %}
{% endif %}
{%- if huw.data|count != 0 %}
{% if huw.data|count == 1 %}
{%- set ww = "viert" -%}
{%- set pers = "koppel" -%}
{%- else -%}
{%- set ww = "vieren" -%}
{%- set pers = "koppels" -%}
{%- endif -%}
'er ' + ww + ' vandaag ' + huw.data|count|string + " " + pers + ' hun Huwelijksverjaardag',
] | random }}
, zijnde:
{% for i in range(0, huw.data|count) %}
{{huw.data[i].wie}}
{% if huw.data[i].jr <= "2" %}
zijn
{{ now().strftime("%Y")|int-huw.data[i].jr|int}}
jaar Getrouwd
{% endif %}
{%- if i + 2 == huw.data|count -%}
{{" "-}}en
{%- elif i + 2 < huw.data|count -%}
{% endif %}
{% endfor %}
'Vergeet deze niet te feliciteren',
'Vergeet geen berichtje te doen',
'Vergeet niet even contact op te nemen',
'Denk daar even aan vandaag',
'Denk eraan om deze proficiat te wensen',
] | random }}
{% endif %}
{%- if taak.data|count != 0 %}
{% if taak.data|count == 1 %}
{%- set ww = "taak" -%}
{%- else -%}
{%- set ww = "taken" -%}
{%- endif -%}
'Je hebt vandaag ' + taak.data|count|string + " " + ww ,
] | random }}
, zijnde:
{% for i in range(0, taak.data|count) %}
om {{ taak.data[i].uur }} uur , {{taak.data[i].wat}}
{% if taak.data[i].bij| default(false) %}
{% if taak.data[i].bij|title == "Thuis" %}
{% elif taak.data[i].bij|title == "Ziekenhuis" %}
,in het
{% else %}
bij
{% endif %}
{{ taak.data[i].bij }}
{% endif %}
{%- if i + 2 == taak.data|count -%}
{{" "-}}en
{%- elif i + 2 < taak.data|count -%}
{% endif %}
{% endfor %}
{% endif %}
{%- if taakmorg.data|count != 0 %}
{% if taakmorg.data|count == 1 %}
{%- else -%}
{%- endif -%}
'en denk eraan, morgen heb je ' + taakmorg.data|count|string + " " + ww ,
] | random }}
, zijnde:
{% for i in range(0, taakmorg.data|count) %}
{% if taakmorg.data[i].wat.split(" ")[0] == 'Verjaardag' %}
{{taakmorg.data[i].wat.split(" ")[:-1]|join(' ')}}
{% else %}
om {{ taakmorg.data[i].uur }} uur , {{taakmorg.data[i].wat}}
{% endif %}
{% if taakmorg.data[i].bij| default(false) %}
{% if taakmorg.data[i].bij|title == "Thuis" %}
{% elif taakmorg.data[i].bij|title == "Ziekenhuis" %}
,in het
{% else %}
bij
{% endif %}
{{ taakmorg.data[i].bij }}
{% endif %}
{%- if i + 2 == taakmorg.data|count -%}
{{" "-}}en
{%- elif i + 2 < taakmorg.data|count -%}
{% endif %}
{% endfor %}
{% endif %}
{% endmacro %}
{%- endmacro -%}
{% if call_Begroeting == 1 %}
{{ Begroeting() }}
{% endif %}
{% if call_Verjaardag == 1 %}
{{ Verjaardag() }}
{% endif %}
{% if call_Datum == 1 %}
{{ Datum() }}
{% endif %}
{% if call_Tijd == 1 %}
{{ Tijd() }}
{% endif %}
{% if call_tempnu == 1 %}
{{ tempnu() }}
{% endif %}
{% if call_wolknu == 1 %}
{{ wolknu() }}
{% endif %}
{% if call_Weerbericht == 1 %}
{{ Weerbericht() }}
{% endif %}
{% if call_Taken == 1 %}
{{ Taken() }}
{% endif %}
{% if call_Waterdruk == 1 %}
{{ Waterdruk() }}
{% endif %}
{%- endmacro -%}
- service: counter.increment
data: {}
entity_id: |-
counter.dagmelding
{% else %}
none
{% endif %}
data: {}
entity_id: |-
{% if call_Feestdag == 1 %}
counter.feestdagmelding
{% else %}
none
{% endif %}
trace:
stored_traces: 40
mode: parallel
max: 50
