Problem with "and conditions"
I tried to code a automation with “and / or conditions” and get the error message: not supported condition: and
my code:
alias: Küche Licht an
  - entity_id: binary_sensor.fibaro_system_fgms001zw5_motion_sensor_sensor
    platform: state
    to: 'on'
  condition:
    condition: and
    conditions:
    - condition: state
      entity_id: light.fibaro_system_fgd212_dimmer_2_level_3
      state: 'off'
    - condition: or
      conditions:
      - condition: sun
        after: sunset
      - condition: sun
        before: sunrise
  - service: light.turn_on
  - delay: 0:05
  - service: light.turn_off
Does somebody has an idea where the error is?
Formatting? Your spacing looks different to mine, otherwise it looks completely the same,
  condition:
    condition: and
    conditions:
      - condition: state
        entity_id: group.people_status
        state: 'home'
      - condition: or
        conditions:
        - condition: state
          entity_id: input_boolean.empty_dishwasher
          state: 'on'
        - condition: state
          entity_id: input_boolean.empty_washingmachine
          state: 'on'
        - condition: state
          entity_id: input_boolean.empty_dryer
          state: 'on'
“not supported condition” is an error in the UI editor because OR conditions aren’t supported by it.
What happens when you actually run the code?
I’ve seen this before. The solution I went with was to use the alternative format for and:
  condition:
    - condition: state
      state: 'off'
    - condition: or
      conditions:
      - condition: sun
        after: sunset
      - condition: sun
        before: sunrise
It will treat each condition as and when just listed in condition:.
Thank you for your answers. I think mf_social is right. It seems to be an error in the UI Editor. Everything is fine now.
