I dared to create automations in automation editor but there are some conditions that need and , or so I made the conditions in the editor and added and, or later in automations.yaml but it doesnt work and seems to give errors can anyone take a look to the and , or conditions please and help me?
- id: '1561721642302'
alias: Irrigation turn on, then off 10 minutes later
- event: sunset
platform: sun
condition:
condition: and
conditions:
- condition: state
entity_id: calendar.summer_automations
state: 'on'
- condition: state
entity_id: weather.dark_sky
state: clear
condition:
condition: or
conditions:
- condition: state
state: cloudy
- condition: state
state: partlycloudy
- data:
entity_id: switch.sonoff_10004115ce
service: switch.turn_on
- delay: 'minutes: 10'
- data:
service: switch.turn_off
It’s not entirely clear what logic you are going after as your indentation is way off and you have some extraneous “condition” statements. The config below will only be true if:
(calendar.summer_automations is on AND weather.dark_sky is clear ) AND ( weather.dark_sky is cloudy OR weather.dark_sky is partlycloudy )
However, as weather.dark_sky can’t be both clear AND (cloudy OR partlycloudy) this will never be true. But the formatting should help you get the logic right.
condition: # top level is AND by default
- condition: and
conditions:
- condition: state
state: 'on'
- condition: state
state: 'clear'
- condition: or
conditions:
- condition: state
state: 'cloudy'
- condition: state
state: 'partlycloudy'
You’re missing a logic function where your first comma is.
This is the default
calendar AND clear weather
AND
cloudy weather OR partly cloudy weather
Assume the calendar is true. It can’t be clear AND (cloudy OR partly cloudy), thus it evaluates as false. If the calendar is false the statement is also false. Thus It will never be true.
Do you want this instead:
OR
well let me put it in an another way I want my sprinkler to use the calendar (cause it defines what days to water from may to september) by any means but I want it to water either in clear , cloudy or partly cloudy weather cause forecasts sometimes aint accurate
- condition: state
state: 'on'
- condition: or
conditions:
- condition: state
state: clear
- condition: state
state: cloudy
- condition: state
state: partlycloudy
