Hello everyone. I am having problems with this automation and it is not possible to verify what the problem is.
Wake automation is a light when others turn off
The problem is that at night it activates itself randomly
It occurs to me to ask if the light that goes off was on for a few seconds, but I don’t know how.
I hope the translation is understood.
Thank you very much.
- alias: "Enciende pasillo a media luz cuando apague alguna luz a la noche"
mode: parallel
- platform: state
entity_id: switch.cocina
to: "off"
- platform: state
entity_id: switch.banio
to: "off"
- platform: state
entity_id: switch.cuarto_florencia
to: "off"
- platform: state
entity_id: switch.cuarto_principal
to: "off"
- platform: state
entity_id: switch.cuarto_milena
to: "off"
condition:
- condition: and
conditions:
- condition: state
entity_id: switch.comedor_1
state: "off"
- condition: state
entity_id: switch.comedor_2
state: "off"
- condition: state
entity_id: switch.10010f3073
state: "off"
- condition: state
entity_id: sun.sun
state: "below_horizon"
- service: light.turn_on
entity_id: light.luz_pasillo # deberia haber un grupo para que se enciendan todas
brightness: 3
kelvin: 2700
- delay:
seconds: 10
- service: light.turn_off
entity_id: light.luz_pasillo_1
entity_id: light.luz_pasillo_2
entity_id: light.luz_pasillo_3
- service: switch.turn_off
The problem is likely that one or more switch is momentarily ‘unavailable’ or ‘unknown’ then returns to ‘off’, triggering the automation. To fix it, set a “from: on” for each trigger.
En Español
Es probable que el origen del problema es que uno de los interruptores estén momentáneamente “no disponibles” o “desconocidos” y luego regresen a “off”, lo cual iniciará la automatización. Para solucionarlo, establezca un “from: on” para cada gatillo.
Ademas, el condición “And” no es necessario en este caso porque los condiciones son “And” de moda predeterminada.
mode: parallel
- platform: state
to: "off"
- platform: state
to: "off"
- platform: state
to: "off"
- platform: state
to: "off"
- platform: state
to: "off"
condition:
- condition: state
state: "off"
- condition: state
state: "off"
- condition: state
state: "off"
- condition: state
entity_id: sun.sun
brightness: 3
kelvin: 2700
- delay:
seconds: 10
For future reference, it isn’t necessary to define five State Triggers, one for each switch entity. You can consolidate them into a single State Trigger.
- platform: state
entity_id:
- switch.cocina
- switch.banio
- switch.cuarto_florencia
- switch.cuarto_principal
- switch.cuarto_milena
to: 'off'
