The reason I’ve tried this is because I’ve got a kettle that sometimes doesn’t automatically stops so I want to set a timer to turn of the switch when the kettle have been on and running for 6 mins (top boiling time for full kettle)
So I thought I’d use the “Add Automation” page. Seamed straight forward but nu luck. The automation doesn’t trigger.
Tried to restart and reload everything.
Any help is greatly appreciated!
This is the code that was put in the /config/automations.yaml
(removed id’s and replaced with xxx)
- id: 'xxx'
alias: Turn of kettle after 3 min and its on
description: ''
- platform: state
to: 'on'
entity_id: switch.kitchen_kettle_switch
condition:
- type: is_power
condition: device
device_id: xxx
entity_id: sensor.kitchen_kettle_power
domain: sensor
above: 2000
- condition: device
type: is_on
device_id: xxx
domain: switch
for:
hours: 0
minutes: 0
seconds: 10
milliseconds: 0
- type: turn_off
device_id: xxx
domain: switch
mode: single
Should as well that the trigger is me pressing the button on the smart plug. It registers in the dashboard when I toggle the button on the plug. Also tried triggering from HA but no difference.
