I have numerous automations that fail to trigger in .91.0 and .91.1. I do see the state being reflected in states.
Here is one that fails:
Also, I am manually editing in automations.yaml, I’m careful and have checked my ID: numbers are unique. I just use the next number, i.e. increment by one, is that ok?
Before adding initial_state: true, did you check the States page to confirm the affected automations were on and not off?
After a restart, Home Assistant restores all automations to their previous state. If they were on, they will be restored to on. If they were off, they will be restored to off.
If Home Assistant encounters an error during its startup, it may fail to restore automations to their previous state. When it finally does restart successfully, it may set (not restore) all automations to off.
initial_state: true is an option that overrides the restore function. The option instructs Home Assistant to always set the automation to on even if it was previously off. In other words, if you choose to temporarily turn off an automation, it will be automatically turned back on after a restart.
FWIW, I don’t have restart failures so none of my automations use initial_state: true. They all get restored to their correct state (whether on or off) after a restart.
To help others here, I experiment with numerous automations, entities, and templates on my test system (Docker version of Home Assistant on a notebook PC). The experimentation process can subject the test system to several restarts in just one day. I’ve yet to encounter the situation where some or all automations fail to be restored correctly. It works as advertised and that’s why I don’t use initial_state: true.
So when I read reports that the restore feature fails and sets automations to 'off` I think “Well now, that’s special.”
