Problem with button card, template and variables
Hi, i have a problem with variables in button card.
So, i want to take the temperature of climate entity (passed with variables) and increase by 0.5 degrees.
This is for button minus and plus in a thermostat card.
But, i receive this error: undefined is not an object (evaluating variables.entity.attributes.temperature)
This is my code:
card:
              type: "custom:button-card"
              template: widget_icon
              tap_action:
                action: call-service
                service: climate.set_temperature
                service_data:
                  temperature: " [[[ return (variables.entity.attributes.temperature + 0.5) ]]]"
                  entity_id: "[[[ return variables.entity ]]]"
              icon: "mdi:plus"
You don’t actually need to use variables here, just grab the attributes directly from your entity.
From inside a JS template, you can access the parent entity's state using entity.state and its attributes with entity.attributes.<attribute_id>.
Try this:
card:
  type: custom:button-card
  tap_action:
    service_data:
      temperature: '[[[ return (entity.attributes.temperature + 0.5); ]]]'
      entity_id: '[[[ return entity.entity_id; ]]]'
  icon: mdi:plus
You’ll also need to specify an entity: for your card, unless it’s already included in the widget_icon template you’re importing.
I want to create a template to which I pass variables. It works well except for this kind of code.
The call of the template
type: 'custom:button-card'
template: tuiles-pieces
variables:
    var_icone: 'ios:sofa#fullcolor'
    var_nom_piece: 'Salon'
    var_path: 'sous-vue-piece-salon'
    var_etat_thermostat: 'sensor.ajout_etat_thermostat_salon'
    var_temperature: 'sensor.ajout_sensor_temperature_salon'
    var_humidite: 'sensor.ajout_sensor_humidite_salon'
    var_lumiere_lampes: 'light.salon'
    var_lumiere_lampes_icone: 'mdi:lamps'
In the template
    ent01: |
        return `<ha-icon
          icon="[[[ variables.var_lumiere_lampes_icone ]]]"
          </ha-icon>`
Ne fonctionne pas????
Can you tell me how to do it?
