Problem with "choose" action in automation
Hi All. Thanks in advance for the support.
Here is the problem I’m having:
As you see, in my automation I have two nested “choose” actions:
As you can see, the automation is going with the default path, and no default path is configured…
The automation is supposed to allow me to pick the days to run my irrigation schedule on the UI through input boolean like these:
so, all the options correspond to one day of the week.
Any ideas? here is the yaml in case anyone wants it.
alias: Balcon 3
description: ""
  - platform: time
    at: input_datetime.hora_balcon
  - platform: device
    type: turned_on
    device_id: 700e6d8c988b5b8bceb471c3ace9ffea
    entity_id: switch.balcon
    domain: switch
condition: []
  - choose:
      - conditions:
          - condition: trigger
            id:
              - Automatico1
          - condition: not
            conditions:
              - condition: state
                entity_id: weather.casa
                state: pouring
              - condition: state
                state: lightning-rainy
              - condition: state
                state: rainy
              - condition: state
                state: snowy-rainy
        sequence:
          - choose:
              - conditions:
                  - condition: state
                    entity_id: input_boolean.z1_lun
                    state: "on"
                  - condition: time
                    weekday:
                      - mon
                sequence:
                  - type: turn_on
                    entity_id: c89989b28bd23e5068e997675d27a59a
                    domain: switch
                  - data:
                      duration: 00:{{ states('input_number.duracion_balcon') | int }}:00
                      entity_id: timer.restante_balcon
                    action: timer.start
              - conditions:
                  - condition: state
                    entity_id: input_boolean.z1_mar
                    state: "on"
                  - condition: time
                    weekday:
                      - tue
                sequence:
                  - type: turn_on
                    domain: switch
                  - data:
                    action: timer.start
              - conditions:
                  - condition: state
                    entity_id: input_boolean.z1_mie
                    state: "on"
                  - condition: time
                    weekday:
                      - wed
                sequence:
                  - type: turn_on
                    domain: switch
                  - data:
                    action: timer.start
              - conditions:
                  - condition: state
                    entity_id: input_boolean.z1_jue
                    state: "on"
                  - condition: time
                    weekday:
                      - thu
                sequence:
                  - type: turn_on
                    domain: switch
                  - data:
                    action: timer.start
              - conditions:
                  - condition: state
                    entity_id: input_boolean.z1_vie
                    state: "on"
                  - condition: time
                    weekday:
                      - fri
                sequence:
                  - type: turn_on
                    domain: switch
                  - data:
                    action: timer.start
              - conditions:
                  - condition: state
                    entity_id: input_boolean.z1_sab
                    state: "on"
                  - condition: time
                    weekday:
                      - sat
                sequence:
                  - type: turn_on
                    domain: switch
                  - data:
                    action: timer.start
              - conditions:
                  - condition: state
                    entity_id: input_boolean.z1_dom
                    state: "on"
                  - condition: time
                    weekday:
                      - sun
                sequence:
                  - type: turn_on
                    domain: switch
                  - data:
                    action: timer.start
      - conditions:
            id:
              - Manual
        sequence:
          - data:
            action: timer.start
  - parallel:
      - sequence:
          - delay: 00:{{ states('input_number.duracion_balcon') | int }}:00
          - type: turn_off
            domain: switch
        alias: Esperar y apagar riego
      - alias: Logica de Restante
        sequence:
          - wait_for_trigger:
              - platform: state
                entity_id:
                  - switch.balcon
                to: "off"
            continue_on_timeout: false
          - data: {}
            action: timer.finish
mode: restart
Not defining a default action does not mean there is no default path. If none of the conditions succeed, nothing is done and the actions below the choose get executed.
It helps us help you if you share the YAML of the automation.
