I have a very simple rest_command:
rest_command:
execute_xenia_script:
url: "http://xenia.local/execute_script?ID={{ script_id }}"
The command has.a variable parameter as a two digit number.
Using DevTools - Services delivers the expected outcome.
Using a Button-Card with a static parameter, it works similarly well.
show_name: true
show_icon: true
type: button
entity: input_text.xenia_script_17
tap_action:
action: call-service
service: rest_command.execute_xenia_script
script_id: '17'
As soon as I use any kind of template for the data: part it all breaks apart and the intended function is not executed.
show_name: true
show_icon: true
type: button
tap_action:
script_id: >
{{ states.input_text.xenia_script_17.name[-2:] | int | string}}
Testing the same approach with a notify service (changing “script_id” to “message”) I see the expected outcome “17” displayed in the message.
Where is my mistake or what is missing to get this combination of rest_command, parameter and template operational?
P.S. I currently use the button-card just for simplification, as the intended use-case is an auto-entities card, but breaking apart at exactly the same point.
