Hello, after an update, the cat /sys/class/thermal/thermal_zone0/temp command that gave me about 50 degrees Celsius gives only 27 degrees.
The equipment is an atom N3160. If I connect via ssh and run the command
[core-ssh ~]$ cat /sys/class/thermal/thermal_zone0/temp
26800
I have installed apk add lm-sensors and it gives me the following output:
[core-ssh ~]$ sensors
acpitz-acpi-0
Adapter: ACPI interface
temp1: +26.8°C (crit = +95.0°C)
In any case, I know that the temperature should be around 50 degrees, since it is a device without a fan. I think it may be a linux kernel thing but I don’t know much about it
[core-ssh ~]$ join me -a
Linux core-ssh 6.1.34 #1 SMP PREEMPT_DYNAMIC Thu Jun 15 14:59:51 UTC 2023 x86_64 Linux
Any idea what it could be?
the version of HA is:
Home Assistant 2023.7.2
Supervisor 2023.07.1
Operating System 10.3
Frontend 20230705.1 - latest
Good morning, it is a device without a fan. The temperature it gives is too stable, it does not vary at all for days despite the fact that I put a fan on it or not. And before the update it did vary depending on whether to put a fan on it to cool down the PC. and it marked over 50 degrees
thanks for answering
I think it was this bios option that made it not work. before it was disabled. In any case, it seems very strange to me because I haven’t touched it and it worked before. In fact, the PC does not even have a keyboard and screen to modify it. The thing is, it works fine now. Or maybe it was an update. Here I put an image of when it is without the fan since it reaches 50 °. And when I put the fan on
