I try to scrape a simple text from a very simple webpage. The commandline is very suboptimal, but it works in the HA docker container - I wanted to try it out before tweaking the command…
When loading it in HA, the sensor value is empty. Please note that I integrate my sensors via the following in “configuration-yaml”:
sensor: !include_dir_list sensors
and each sensor has its own file, which content is the below. Thus e.g. “platform” has no indent or hyphen.
platform: command_line
command: "curl 'https://opendata.dwd.de/weather/text_forecasts/html/VHDL50_DWPG_LATEST_html' 2>&1 | awk '/<pre/,/<\/pre>/' | sed 's/^<[\/a-z\"-:= ]*>//g' | tr -d '\n' | tr -d '\r'"
name: "Wetter heute Berlin"
scan_interval: 900
The intention is to read the summary or the full weather text, I will most likely do everything in awk, but I am not aware of full awk syntax, thus using the weird combination of commandline tools :-)…
I tried to use the scrape sensor as well:
platform: scrape
resource: https://opendata.dwd.de/weather/text_forecasts/html/VHDL50_DWPG_LATEST_html
select: "pre"
but this doesnt work (with ’ select: “strong” ’ it works for the summary at least). According to my reading from beautiful soap it should work, but the output is “unknown”… This is why I tried the commandline sensor above as well.
Thanks, regards
