Problem with configuration.yaml and Visual estudio
I am a newbie in home assistant and I have installed hacs, for this I have added in configuration.yaml a line with the personal access token to Github, Visual studio gives me an error: “String don´t match the pattern …”. Actually HACS works fine for me, but I don’t know how to get the Visual Esudio error.
Does anybody have an idea?
Have you tried installing HACS via the UI as follows?
Yes, I followed the steps and everything was fine, but when starting the service it gave an error of limit access in 1 hour, looking in the forum I found the thing to put a personal token in the configuration.yaml.
That worked, although the VS gives me that error, but the system checker gives no error.
do you think i don’t need it?
