Hi, I have problem with connecting my Conbee 2.
I’m currently running Hassio 0.91.4 on Rasberry Pi. I have connected the Conbee stick to USB port on the Pi. Installed the Deconz addon (which apparently was discovered by Home Assistant), changed its config to device": “/dev/ttyUSB0” but when I start the addon I keep getting “Wait reconnect x seconds” (full log below). When I open the WebUi the stick apparently is also not connetced (in settings it says: “Firmware Not connected”; “ZigBee channel 0”, “Network id 0x0000”). Am I missing something?
{"uuid":"951d35b8c2b645e1b12e72e976e41347"}
[10:48:51] INFO: Success send discovery information to Home Assistant
[10:48:51] INFO: deCONZ is setup and running
libpng warning: iCCP: known incorrect sRGB profile
This plugin does not support propagateSizeHints()
10:48:51:685 HTTP Server listen on address 0.0.0.0, port: 40850, root: /usr/share/deCONZ/webapp/
10:48:57:125 CTRL. 3.16.210:48:57:218 dev /dev/ttyAMA0
10:48:57:218 COM: --dev: /dev/ttyUSB0 (ConBee)
10:48:57:218 ZCLDB init file /data/.local/share/dresden-elektronik/deCONZ/zcldb.txt
10:48:57:384 parent process bash
10:48:57:384 gw run mode: docker/hassio
10:48:57:384 GW sd-card image version file does not exist: /data/.local/share/dresden-elektronik/deCONZ/gw-version
10:48:57:384 sd-card cid: 1b534d454231515430ffffffff0124a3
10:48:57:386 DB sqlite version 3.16.2
10:48:57:387 DB PRAGMA page_count: 30
10:48:57:387 DB PRAGMA page_size: 4096
10:48:57:387 DB PRAGMA freelist_count: 0
10:48:57:387 DB file size 122880 bytes, free pages 0
10:48:57:387 DB PRAGMA user_version: 6
10:48:57:387 DB cleanup
10:48:57:388 DB create temporary views
10:48:57:396 don't close database yet, keep open for 900 seconds
10:48:57:397 started websocket server at port 40860
10:48:57:401 discovery updated announce interval to 10 minutes
10:48:57:404 found node plugin: libde_rest_plugin.so - REST API Plugin
10:48:57:408 found node plugin: libde_signal_plugin.so - Signal Monitor Plugin
10:48:59:645 found node plugin: libstd_otau_plugin.so - STD OTAU Plugin
10:48:59:674 dev /dev/ttyAMA0
10:48:59:674 COM: --dev: /dev/ttyUSB0 (ConBee)
10:48:59:735 dev /dev/ttyAMA0
10:48:59:735 COM: --dev: /dev/ttyUSB0 (ConBee)
10:48:59:763 dev /dev/ttyAMA0
10:48:59:763 COM: --dev: /dev/ttyUSB0 (ConBee)
10:49:00:753 wait reconnect 15 seconds
10:49:00:800 dev /dev/ttyAMA0
10:49:00:800 COM: --dev: /dev/ttyUSB0 (ConBee)
10:49:01:803 wait reconnect 14 seconds
10:49:02:460 dev /dev/ttyAMA0
10:49:02:694 Announced to internet
10:49:02:695 discovery server date: Wed, 01 May 2019 08:49:02 GMT
10:49:02:695 local time seems to be ok
10:49:02:695 discovery found version 2.04.35 for update channel stable
10:49:02:853 wait reconnect 13 seconds
10:49:03:903 wait reconnect 12 seconds
10:49:04:920 wait reconnect 11 seconds
10:49:05:920 wait reconnect 10 seconds
10:49:06:920 wait reconnect 9 seconds
10:49:07:358 New websocket 192.168.1.115:59382 (state: 3)
10:49:07:920 wait reconnect 8 seconds
10:49:08:920 wait reconnect 7 seconds
10:49:09:920 wait reconnect 6 seconds
10:49:10:920 wait reconnect 5 seconds
10:49:11:920 wait reconnect 4 seconds
10:49:12:457 dev /dev/ttyAMA0
10:49:12:920 wait reconnect 3 seconds
10:49:13:920 wait reconnect 2 seconds
10:49:14:920 wait reconnect 1 seconds
10:49:14:959 dev /dev/ttyAMA0
10:49:14:959 COM: --dev: /dev/ttyUSB0 (ConBee)
10:49:15:960 dev /dev/ttyAMA0
10:49:15:960 COM: --dev: /dev/ttyUSB0 (ConBee)
10:49:15:988 dev /dev/ttyAMA0
10:49:15:988 COM: --dev: /dev/ttyUSB0 (ConBee)
10:49:16:965 dev /dev/ttyAMA0
10:49:16:965 COM: --dev: /dev/ttyUSB0 (ConBee)
10:49:16:994 dev /dev/ttyAMA0
10:49:16:994 COM: --dev: /dev/ttyUSB0 (ConBee)
10:49:17:920 wait reconnect 15 seconds
10:49:17:963 dev /dev/ttyAMA0
10:49:17:963 COM: --dev: /dev/ttyUSB0 (ConBee)
10:49:18:920 wait reconnect 14 seconds
10:49:19:920 wait reconnect 13 seconds
10:49:20:920 wait reconnect 12 seconds
10:49:21:920 wait reconnect 11 seconds
10:49:22:464 dev /dev/ttyAMA0
10:49:22:920 wait reconnect 10 seconds
10:49:23:920 wait reconnect 9 seconds
10:49:24:919 wait reconnect 8 seconds
10:49:25:920 wait reconnect 7 seconds
10:49:26:920 wait reconnect 6 seconds
10:49:27:920 wait reconnect 5 seconds
10:49:28:920 wait reconnect 4 seconds
10:49:29:920 wait reconnect 3 seconds
10:49:30:920 wait reconnect 2 seconds
10:49:31:920 wait reconnect 1 seconds
10:49:31:965 dev /dev/ttyAMA0
10:49:31:965 COM: --dev: /dev/ttyUSB0 (ConBee)
10:49:32:466 dev /dev/ttyAMA0
10:49:32:960 dev /dev/ttyAMA0
10:49:32:960 COM: --dev: /dev/ttyUSB0 (ConBee)
10:49:32:989 dev /dev/ttyAMA0
10:49:32:989 COM: --dev: /dev/ttyUSB0 (ConBee)
10:49:33:961 dev /dev/ttyAMA0
10:49:33:961 COM: --dev: /dev/ttyUSB0 (ConBee)
10:49:33:989 dev /dev/ttyAMA0
10:49:33:989 COM: --dev: /dev/ttyUSB0 (ConBee)
10:49:34:952 wait reconnect 15 seconds
10:49:34:981 dev /dev/ttyAMA0
10:49:34:981 COM: --dev: /dev/ttyUSB0 (ConBee)
