Problem with control electrovalve depending on value of soil moisture sensor
Hi, I have a little problem. I want to write a program in which I can control the valve for a certain period of time depending on the soil moisture of the sensor. I wrote a program where for the moisture intervals:
75-70 = 1:30 min
70-65 = 2 min
65 - 60 = 2:30 min
and <60 = 3 min
After bringing the humidity, for example, from a value of 63% to about 30%, the solenoid valve should turn on for 3 min, and it turns on for 1:30 min each time. Please help. Code:
  - platform: state
    entity_id:
      - switch.esphome_web_74c344_elektrovalve
    to: "on"
    for:
      hours: 0
      minutes: 1
      seconds: 30
  - platform: numeric_state
    entity_id: sensor.esphome_web_74c344_soil_moisture
    above: 70
    below: 75
  - platform: state
    entity_id:
    to: "on"
    for:
      hours: 0
      minutes: 2
      seconds: 0
    above: 65
    below: 70
  - platform: state
    entity_id:
    to: "on"
    for:
      hours: 0
      minutes: 2
      seconds: 30
    above: 60
    below: 65
  - platform: state
    entity_id:
    to: "on"
    for:
      hours: 0
      minutes: 3
      seconds: 0
    below: 60
    above: 1
condition:
  - condition: sun
    before: sunrise
    after: sunset
    enabled: false
  - choose:
      - conditions:
          - condition: trigger
            id:
              - auto_wl_75_70
        sequence:
          - service: switch.turn_on
            data: {}
              entity_id: switch.esphome_web_74c344_elektrovalve
      - conditions:
            id:
              - auto_wyl_75_70
        sequence:
          - service: switch.turn_off
            data: {}
      - conditions:
            id:
              - auto_wl_70_65
        sequence:
            data: {}
      - conditions:
            id:
              - auto_wyl_70_65
        sequence:
            data: {}
      - conditions:
            id:
              - auto_wl_65_60
        sequence:
            data: {}
      - conditions:
            id:
              - auto_wyl_65_60
        sequence:
            data: {}
      - conditions:
            id:
              - auto_wl_60
        sequence:
            data: {}
      - conditions:
            id:
              - auto_wyl_60
        sequence:
            data: {}
mode: single
