I currently have a problem with location tracking.
I am using the HA app on my wife’s smartphone and on mine and have also enabled all the required entities.
It is correctly detected when someone is in the “home area” (so the router detects a presence), but beyond that no display takes place. When I or my wife leave the home area, no location tracking takes place and HA still shows the device as a circle in the home area.
(See screenshot).
What do I have to set for the tracking to work properly?
(We both use Android)
I would really appreciate it if you could help me.
exactly, my wife is not at home, but in the map it is shown as home. Conversely, your real current location is not shown to me. The entity strangely outputs the following:
and these coordinates are in the home zone.
Although she is just about 30km away. Now I would like your correct location to be shown to me on the map as well.
Because only if this happens, I can also plan with the work zone and also use the location map correctly.
@hpoperator Have you subscrived to Nabu Casa cloud?
Otherwise the companion app can’t be used as a device tracker when away as there is no way to tell your HA instance the location updates…
Andreas is correct.
You would have to figure out a setup in a way that your phones can reach your HA server from outside, so that to update the location of the phone back to HA.
If not Nabu Casa, there are many other less simple (but free) ways also. You could do Duck DNS + NGINX Home Assistant SSL proxy + opening a port mapping on your router, you could do VPN, you could do ZeroTier or Tailscale.
