Hi to all, i’ve managed to install duckdns and NGINX and properly configured those addon, then i’ve forwarded the ports 443 & 8123 to the respective ones of the of the home assistant from the modem page but i cannot access them over the internet.
What can i do to fix this?
The certificates are reporting correctly my duckdns address and the duckdns addon updates the IP correctly (because it’s the same one that plex uses so i was able to compare them easily) but when i try to access home assistant from anywhere but locally i get a “connection refused” error.
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
homeassistant:
internal_url: "https://192.168.0.107:8123"
external_url: !secret https_address
http:
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
ip_ban_enabled: True
login_attempts_threshold: 3
this is my configuration.yaml file
