Hi to all.
I have been using the energy module since it was released and have always found it very useful.
I have 3 Shelly sensors for consumption, production and placing.
On October 07 I made two operations:
I updated to version 2021.10.1
I added and immediately deleted two sensors for individual devices (shelly 1PM for washing machine and shelly 1PM for dryer).
From that day on, I can’t see the energy stats anymore and I don’t understand why.
The sensors detect the values correctly, as you can see in image.
There is an error in the log:
2021-10-11 15:08:55 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [548380868768] Received invalid command: energy/info
Yes, I solved it.
In my case, it was a problem related to the installation of the 2021.10 release causing a problem on the MariaDB database. The problem has been fixed with the 2021.10.4 release. In this topic you will find more information:
having the same issue [homeassistant.components.websocket_api.http.connection] [2975217528] Received invalid command: energy/info on the latest non beta verson
ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [140060227029984] Received invalid command: energy/info
I have same errors in core log. Every time when restarting core those error will be logged. When restarting HA host no errors. Energy monitor space working fine.
Running:
core-2021.12.10
supervisor-2021.12.2
Home Assistant OS 7.2
