Is anyone else having issues with Flux LED/MagicLight where all lights discovered do not have a device ID associated to them?Without that, it is impossible to automate any of the lights discovered.
Only integrations that use âconfig flowâ can create devices. Integrations that are setup in configuration.yaml canât.
Anyway, you donât need a device to create an automation, all entities can been used to create automations.
Iâm not sure I follow 100%. So if I integrate with TUYA, all the devices I registered there have a device ID and Iâm able to automate however, integration with MAGIC LIGHT (using Flux LED) donât generate. Hence, I am not able to automate anything because I donât get a device ID. I mean, I can configure the names and all but that is about it. So I guess there is no FIX for this right now? I guess a limitation of the MAGIC LIGHT implementation?
OK so let me explain what I am trying to do. I have a trigger for when phones are away to close all lights. For that I need to set conditions for the devices or entities. As it stands, since my FLEX LED / Magic Lights canât be found as entities or devices, there is no way for me to set their condition to off.
This comes from the entity list⌠So I was wrong with my previous statement, they will show as an entity however when I set the conditions for automation and select DEVICE, it is not in the device list! There is just no way for me to automate anything FLEX LED / MAGIC LIGHT related, nothing in there will ever show. And I cannot select ENTITY in the list of ACTION TYPEs for the ACTION.
The problem is in the text of the image I sent, there is no âUNIQUE IDâ for those.
And I did try to customize them too but that doesnât work, but I can configure a friendly name :
- light.6001949123d0_192_168_20_159:
entity_id: 9eb1f3feb2014d39805e
friendly_name: Computer DESK LED
- light.6001949557fd_192_168_20_158:
entity_id: e659eae464994a3ab2d9
friendly_name: Bookshelf LED
That config is placed in customize.yaml
That ID was self generated. Anyways just doesnât work and unless I get a device ID setup for the MAGIC Lights I donât see a way around this problem. As far as I am concerned it is a bug or limitation of this integration.
So Action Type : Call Service works. I guess I missed that one or didnât look well enough in the list of services but it is a way around my problem.
So my question now is, why is TUYAâs integration generate unique IDs (i.e. devices which leads to Device IDs) for all the stuff defined in it and MAGIC LIGHT / Flux_LED doesnât? Seriously why is it different? Every object that gets imported from an integration should get its own unique ID as far as I am concerned.
Anyways for now the problem is solved and this offers a way around the problem but I still find it odd and consider this a bug that FLUX_LED / MAGIC Lightâs integration doesnât create unique IDs for the items discovered there.
Thanks for the work around. Hopefully they enhace MAGIC LIGHTâs integration soon or in the future.
So that should allow them to work better with Alexa integration via Nabu Casa subscription I imagine? As of now, I have successfully integrated the flux_led component for an RGBW LED Strip, but I canât turn it on by voice like I desire due to lack of Device ID/name.
