Problem with HA Supervised installation
I tried to install HA Supervised on Debian 11 Bullseye using this guide: Installing Home Assistant Supervised on Debian 11 . After installation I got logs like this:
-- Journal begins at Sun 2022-06-26 13:45:57 CEST. --
Jun 26 13:59:58 debian-ha sshd[9987]: Disconnected from invalid user motorola 176.102.38.42 port 45218 [preauth]
Jun 26 14:00:04 debian-ha 5da2306b58b7[8496]: 22-06-26 14:00:04 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/amd64-hassio-cli with tag 2022.05.0.
Jun 26 14:00:04 debian-ha dockerd[8496]: time="2022-06-26T14:00:04.102868909+02:00" level=warning msg="Error getting v2 registry: Get \"https://ghcr.io/v2/\": dial tcp: lookup ghcr.io on [::1]:53: read udp [::1]:48800->[::1]:53: read: connection refused"
Jun 26 14:00:04 debian-ha dockerd[8496]: time="2022-06-26T14:00:04.103024535+02:00" level=info msg="Attempting next endpoint for pull after error: Get \"https://ghcr.io/v2/\": dial tcp: lookup ghcr.io on [::1]:53: read udp [::1]:48800->[::1]:53: read: connection refused"
Jun 26 14:00:04 debian-ha dockerd[8496]: time="2022-06-26T14:00:04.105724955+02:00" level=error msg="Handler for POST /v1.41/images/create returned error: Get \"https://ghcr.io/v2/\": dial tcp: lookup ghcr.io on [::1]:53: read udp [::1]:48800->[::1]:53: read: connection refused"
Jun 26 14:00:04 debian-ha 5da2306b58b7[8496]: 22-06-26 14:00:04 ERROR (SyncWorker_0) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/amd64-hassio-cli:2022.05.0: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2022.05.0&fromImage=ghcr.io%2Fhome-assistant%2Famd64-hassio-cli&platform=linux%2Famd64: Internal Server Error ("Get "https://ghcr.io/v2/": dial tcp: lookup ghcr.io on [::1]:53: read udp [::1]:48800->[::1]:53: read: connection refused")
Jun 26 14:00:04 debian-ha 5da2306b58b7[8496]: 22-06-26 14:00:04 WARNING (MainThread) [supervisor.plugins.cli] Error on install cli plugin. Retry in 30sec
Jun 26 14:00:07 debian-ha systemd[1]: Starting system activity accounting tool...
Jun 26 14:00:07 debian-ha systemd[1]: sysstat-collect.service: Succeeded.
Jun 26 14:00:07 debian-ha systemd[1]: Finished system activity accounting tool.
Jun 26 14:00:34 debian-ha 5da2306b58b7[8496]: 22-06-26 14:00:34 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/amd64-hassio-cli with tag 2022.05.0.
Jun 26 14:00:34 debian-ha dockerd[8496]: time="2022-06-26T14:00:34.158127866+02:00" level=warning msg="Error getting v2 registry: Get \"https://ghcr.io/v2/\": dial tcp: lookup ghcr.io on [::1]:53: read udp [::1]:48893->[::1]:53: read: connection refused"
Jun 26 14:00:34 debian-ha dockerd[8496]: time="2022-06-26T14:00:34.158251531+02:00" level=info msg="Attempting next endpoint for pull after error: Get \"https://ghcr.io/v2/\": dial tcp: lookup ghcr.io on [::1]:53: read udp [::1]:48893->[::1]:53: read: connection refused"
Jun 26 14:00:34 debian-ha dockerd[8496]: time="2022-06-26T14:00:34.160701209+02:00" level=error msg="Handler for POST /v1.41/images/create returned error: Get \"https://ghcr.io/v2/\": dial tcp: lookup ghcr.io on [::1]:53: read udp [::1]:48893->[::1]:53: read: connection refused"
Jun 26 14:00:34 debian-ha 5da2306b58b7[8496]: 22-06-26 14:00:34 ERROR (SyncWorker_0) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/amd64-hassio-cli:2022.05.0: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2022.05.0&fromImage=ghcr.io%2Fhome-assistant%2Famd64-hassio-cli&platform=linux%2Famd64: Internal Server Error ("Get "https://ghcr.io/v2/": dial tcp: lookup ghcr.io on [::1]:53: read udp [::1]:48893->[::1]:53: read: connection refused")
Jun 26 14:00:34 debian-ha 5da2306b58b7[8496]: 22-06-26 14:00:34 WARNING (MainThread) [supervisor.plugins.cli] Error on install cli plugin. Retry in 30sec
What should I do in that case? Can’t run HA in webpage and tried to re-installion couple of times but I got the same problem. Thank You in advance for any help and info!
Next error which I saw in logs:
Jun 26 15:36:26 debian-ha 5da2306b58b7[831]: 22-06-26 15:36:26 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/amd64-hassio-audio with tag 2022.05.0.
Jun 26 15:36:26 debian-ha dockerd[831]: time="2022-06-26T15:36:26.631576307+02:00" level=warning msg="Error getting v2 registry: Get \"https://ghcr.io/v2/\": dial tcp: lookup ghcr.io on [::1]:53: read udp [::1]:59144->[::1]:53: read: connection refused"
Jun 26 15:36:26 debian-ha dockerd[831]: time="2022-06-26T15:36:26.631689579+02:00" level=info msg="Attempting next endpoint for pull after error: Get \"https://ghcr.io/v2/\": dial tcp: lookup ghcr.io on [::1]:53: read udp [::1]:59144->[::1]:53: read: connection refused"
Jun 26 15:36:26 debian-ha dockerd[831]: time="2022-06-26T15:36:26.635446766+02:00" level=error msg="Handler for POST /v1.41/images/create returned error: Get \"https://ghcr.io/v2/\": dial tcp: lookup ghcr.io on [::1]:53: read udp [::1]:59144->[::1]:53: read: connection refused"
Jun 26 15:36:26 debian-ha 5da2306b58b7[831]: 22-06-26 15:36:26 ERROR (SyncWorker_0) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/amd64-hassio-audio:2022.05.0: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2022.05.0&fromImage=ghcr.io%2Fhome-assistant%2Famd64-hassio-audio&platform=linux%2Famd64: Internal Server Error ("Get "https://ghcr.io/v2/": dial tcp: lookup ghcr.io on [::1]:53: read udp [::1]:59144->[::1]:53: read: connection refused")
Jun 26 15:36:26 debian-ha 5da2306b58b7[831]: 22-06-26 15:36:26 WARNING (MainThread) [supervisor.plugins.audio] Error on installing Audio plugin, retrying in 30sec
Jun 26 15:36:27 debian-ha e07a8cf6b46d[831]: [INFO] 127.0.0.1:37581 - 46867 "NS IN . udp 17 false 512" NOERROR - 0 5.973160284s
Jun 26 15:36:27 debian-ha e07a8cf6b46d[831]: [INFO] 127.0.0.1:60464 - 52981 "HINFO IN 843717855134400135.8597757467125477945. udp 67 true 2048" NOERROR - 0 6.478809716s
Jun 26 15:36:27 debian-ha e07a8cf6b46d[831]: [ERROR] plugin/errors: 2 . NS: dial tcp 1.0.0.1:853: connect: no route to host
Jun 26 15:36:27 debian-ha e07a8cf6b46d[831]: [ERROR] plugin/errors: 2 843717855134400135.8597757467125477945. HINFO: dial tcp 1.1.1.1:853: connect: no route to host
Jun 26 15:36:27 debian-ha e07a8cf6b46d[831]: [INFO] 127.0.0.1:39942 - 34039 "NS IN . udp 17 false 512" NOERROR - 0 7.474290154s
Jun 26 15:36:28 debian-ha e07a8cf6b46d[831]: [INFO] 127.0.0.1:55952 - 37121 "HINFO IN 843717855134400135.8597757467125477945. udp 56 false 512" NOERROR - 0 8.002109447s
Jun 26 15:36:28 debian-ha e07a8cf6b46d[831]: [ERROR] plugin/errors: 2 843717855134400135.8597757467125477945. HINFO: read udp 127.0.0.1:34954->127.0.0.1:5553: i/o timeout
Jun 26 15:36:30 debian-ha e07a8cf6b46d[831]: [INFO] 127.0.0.1:53458 - 35525 "HINFO IN 843717855134400135.8597757467125477945. udp 67 true 2048" NOERROR - 0 6.549067083s
Jun 26 15:36:30 debian-ha e07a8cf6b46d[831]: [ERROR] plugin/errors: 2 843717855134400135.8597757467125477945. HINFO: dial tcp 1.1.1.1:853: connect: no route to host
