flotzMAN
(Simon)
February 7, 2024, 8:17am
1
Hello everyone,
Since updating the app to 2024.1.5-full for Android, my widget function no longer works. For each of my old and newly created widgets, the error message “Problem loading the widget” appears.
I have already tried a lot, including deleting the cache, the entire memory of the app and the app itself. Checked the permissions of the app and the launcher.
But now I don’t know what to do.
Are you using the lawnchair launcher? If so existing issue that they need to solve
Judman13
(Judson)
February 8, 2024, 3:57am
3
I am getting Widget Failed to load error using lawnchair.
Do you know anything else. About the issue with lawnchair and if it has been opened as an issue on their github?
Nevermind i see the issue in the home assisant android github and the link to the tesla related issue in the lawnchair github. Thanks!
flotzMAN
(Simon)
February 13, 2024, 1:48pm
4
Yes, i do!
Good to know! do you have an idea when it will be fixed?
only the lawnchair devs can answer that
remizik
(Remi)
February 22, 2024, 10:47pm
7
I can confirm that I have the same issue. I can create a widget without any problem on the stock launcher on my Xiaomi phone.
Rolonl
(Rolonl)
March 5, 2024, 10:22am
8
Same issue, also with Lawnchair
meznak
(Nathan Plamondon)
April 18, 2024, 10:49pm
9
It looks like this might be fixed in a recent alpha (now beta?) Lawnchair release.
Here are the issues so future visitors don’t have to dig for them:
opened 01:05PM - 01 Feb 24 UTC
closed 11:48AM - 04 Apr 24 UTC
bug
question
widget
<!-- READ THIS FIRST:
- Make sure you run the latest version of the Android app…
- Make sure you run the latest version of Home Assistant
- Make sure to check the Companion docs for troubleshooting and configuration: https://companion.home-assistant.io/
- Make sure the bug you found is not already reported, we love to put work in bugfixes instead of closing duplicate bug reports
DO NOT DELETE ANY TEXT from this template! All requested information is important.
**Home Assistant Android app version(s):** 2024.1.5-full
**Android version(s):** 10
**Device model(s):** OnePlus 5T (ONEPLUS A5010) and Redmi Note 8T
**Home Assistant version:** 2024.1.2
**Last working Home Assistant release (if known):** 2024.1.2
**Description of problem, include YAML if issue is related to notifications:** I configure 2 template widget to view faster the state of a sensor from my phone homepage without open app. But this night auto update install new version of companion app 2024.1.5-full and the widget are white background with this message "Errore durante il caricametto del widget" (Italian traslation of Error during template loading).
![image](https://github.com/home-assistant/android/assets/26909922/8c052ba8-5207-476c-b8f4-872ee5c1b1c6)
This is configuration of one of this:
![image](https://github.com/home-assistant/android/assets/26909922/3e53a5be-111b-49a0-9ff3-215314ec8e11)
I also try to make other widget more simple but same error. As you can see in the screen the preview of the widget is ok.
- For Wear OS devices we will need the LogCat logs from the device.
- For Android Auto the logs can be retrieved from the connected device.
- Logs from the device can be taken from Settings > Companion App Troubleshooting > Show and Share Logs
**Companion App Logs:** There is personal data so I try to search in the log but there aren't error regarding widget.
**Screenshot or video of problem:**
**Additional information:**
opened 05:18PM - 03 Feb 24 UTC
bug
outdated
### Describe the bug
Since the last Update of the Tesla App, the Widget ist o… nly showing "Problem with loading the Widget"
On the Pixel Launcher the Problem does not exist, the Widget will be loaded normally.
### Steps to reproduce
Add the Widget to the Start Page
### Expected behavior
Widget should be loaded and shown on the Start Page
### Screenshots
![image](https://github.com/LawnchairLauncher/lawnchair/assets/22996350/eff129e6-7520-4fd8-bd33-bcc7c4b63775)
### Device information
- Device: Google Pixel 6a
- OS: Stock android 14
- App version: 2.0-2589
