Hi, I have a problem with HACS
I have never analyzed a Log
and i’m not understanding how to fix it. Would you give me a hand? Thanks
--------------Log Error---------
2023-05-06 14:47:15.049 WARNING (MainThread) [homeassistant.components.ssdp] Could not set up UPnP/SSDP server, as a presentation URL could not be determined; Please configure your internal URL in the Home Assistant general configuration
2023-05-06 14:47:33.410 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry for hacs
File “/usr/src/homeassistant/homeassistant/config_entries.py”, line 387, in async_setup
result = await component.async_setup_entry(hass, self)
File “/config/custom_components/hacs/init.py”, line 220, in async_setup_entry
setup_result = await async_initialize_integration(hass=hass, config_entry=config_entry)
File “/config/custom_components/hacs/init.py”, line 206, in async_initialize_integration
await async_try_startup()
File “/config/custom_components/hacs/init.py”, line 193, in async_try_startup
startup_result = await async_startup()
File “/config/custom_components/hacs/init.py”, line 171, in async_startup
hass.config_entries.async_setup_platforms(
AttributeError: ‘ConfigEntries’ object has no attribute ‘async_setup_platforms’
2023-05-06 14:47:34.540 WARNING (MainThread) [homeassistant.components.mqtt.client] Can’t decode payload b’{“name”:“CancelliAutomaticiAntMa status”,“stat_t”:“tele/CancelliAutomatici/HASS_STATE”,“avty_t”:“tele/CancelliAutomatici/LWT”,“pl_avail”:“Online”,“pl_not_avail”:“Offline”,“json_attr_t”:"tele/CancelliAutomatici\xc0\x000\xeb\x02\x00"tele/CancelliAutomatici/HASS_STATE{“Version”:“11.0.0(tasmota)”,“BuildDateTime”:“2022-02-12T14:13:50”,“Module or Template”:“Generic”,“RestartReason”:“External System”,“Uptime”:“0T00:31:55”,“Hostname”:“CancelliAutomatici-3012”,"IPA’ on homeassistant/sensor/7B2BC4_status/config with encoding utf-8 (for <Job None HassJobType.Callback <function async_start..async_discovery_message_received at 0xffff864839a0>>)
2023-05-06 14:50:10.303 WARNING (Recorder) [homeassistant.components.sensor.recorder] Entity sensor.presa_coffeemaker_total_consumption from integration broadlink has state class total_increasing, but its state is negative. Triggered by state -1 with last_updated set to 2023-05-06T12:44:59.999999+00:00. Please create a bug report at Issues · home-assistant/core · GitHub
2023-05-06 21:44:21.697 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from host-79-33-230-201.retail.telecomitalia.it (79.33.230.201). Requested URL: ‘/api/states/sensor.0xa4c1383fdd9017fa_temperature’. (Home Assistant/2023.3.0-3260 (Android 13; M2012K11AG))
2023-05-06 22:34:27.634 ERROR (MainThread) [homeassistant.helpers.template] Template variable error: ‘value_json’ is undefined when rendering ‘{{ value_json.state }}’
2023-05-06 22:34:27.656 ERROR (MainThread) [homeassistant.helpers.template] Error parsing value: ‘value_json’ is undefined (value: , template: {{ value_json.state }})
2023-05-06 22:34:27.660 ERROR (MainThread) [homeassistant.helpers.template] Template variable error: ‘value_json’ is undefined when rendering ‘{{ value_json.child_lock }}’
2023-05-06 22:34:27.664 ERROR (MainThread) [homeassistant.helpers.template] Error parsing value: ‘value_json’ is undefined (value: , template: {{ value_json.child_lock }})
2023-05-06 22:34:27.668 ERROR (MainThread) [homeassistant.helpers.template] Template variable error: ‘value_json’ is undefined when rendering ‘{{ value_json.power_outage_memory }}’
2023-05-06 22:34:27.673 ERROR (MainThread) [homeassistant.helpers.template] Error parsing value: ‘value_json’ is undefined (value: , template: {{ value_json.power_outage_memory }})
2023-05-06 22:34:27.677 ERROR (MainThread) [homeassistant.components.mqtt.select] Invalid option for select.0x70ac08fffe84dd26_power_outage_memory: ‘’ (valid options: [‘on’, ‘off’, ‘restore’])
2023-05-06 22:34:27.681 ERROR (MainThread) [homeassistant.helpers.template] Template variable error: ‘value_json’ is undefined when rendering ‘{{ value_json.indicator_mode }}’
2023-05-06 22:34:27.686 ERROR (MainThread) [homeassistant.helpers.template] Error parsing value: ‘value_json’ is undefined (value: , template: {{ value_json.indicator_mode }})
2023-05-06 22:34:27.689 ERROR (MainThread) [homeassistant.components.mqtt.select] Invalid option for select.0x70ac08fffe84dd26_indicator_mode: ‘’ (valid options: [‘off’, ‘off/on’, ‘on/off’, ‘on’])
2023-05-06 22:34:27.693 ERROR (MainThread) [homeassistant.helpers.template] Template variable error: ‘value_json’ is undefined when rendering ‘{{ value_json.power }}’
2023-05-06 22:34:27.699 ERROR (MainThread) [homeassistant.helpers.template] Template variable error: ‘value_json’ is undefined when rendering ‘{{ value_json.energy }}’
2023-05-06 22:34:27.706 ERROR (MainThread) [homeassistant.helpers.template] Error parsing value: ‘value_json’ is undefined (value: , template: {{ value_json[‘update’][‘installed_version’] }})
2023-05-06 22:34:27.718 ERROR (MainThread) [homeassistant.helpers.template] Error parsing value: ‘value_json’ is undefined (value: , template: {{ value_json[‘update’][‘latest_version’] }})
2023-05-06 22:34:27.727 ERROR (MainThread) [homeassistant.helpers.template] Template variable error: ‘value_json’ is undefined when rendering ‘{{ value_json.state }}’
2023-05-06 22:34:27.732 ERROR (MainThread) [homeassistant.helpers.template] Error parsing value: ‘value_json’ is undefined (value: , template: {{ value_json.state }})
2023-05-06 22:34:27.736 ERROR (MainThread) [homeassistant.helpers.template] Template variable error: ‘value_json’ is undefined when rendering ‘{{ value_json.state }}’
2023-05-06 22:34:27.739 ERROR (MainThread) [homeassistant.helpers.template] Error parsing value: ‘value_json’ is undefined (value: , template: {{ value_json.state }})
2023-05-06 22:34:27.742 ERROR (MainThread) [homeassistant.helpers.template] Template variable error: ‘value_json’ is undefined when rendering ‘{{ value_json.state }}’
2023-05-06 22:34:27.744 ERROR (MainThread) [homeassistant.helpers.template] Error parsing value: ‘value_json’ is undefined (value: , template: {{ value_json.state }})
2023-05-06 22:34:27.746 ERROR (MainThread) [homeassistant.helpers.template] Template variable error: ‘value_json’ is undefined when rendering ‘{{ value_json.state }}’
2023-05-06 22:34:27.748 ERROR (MainThread) [homeassistant.helpers.template] Error parsing value: ‘value_json’ is undefined (value: , template: {{ value_json.state }})
2023-05-06 22:34:27.750 ERROR (MainThread) [homeassistant.helpers.template] Template variable error: ‘value_json’ is undefined when rendering ‘{{ value_json.state }}’
2023-05-06 22:34:27.753 ERROR (MainThread) [homeassistant.helpers.template] Error parsing value: ‘value_json’ is undefined (value: , template: {{ value_json.state }})
2023-05-06 22:34:27.755 ERROR (MainThread) [homeassistant.helpers.template] Template variable error: ‘value_json’ is undefined when rendering ‘{{ value_json.state }}’
2023-05-06 22:34:27.758 ERROR (MainThread) [homeassistant.helpers.template] Error parsing value: ‘value_json’ is undefined (value: , template: {{ value_json.state }})
2023-05-06 22:34:27.760 ERROR (MainThread) [homeassistant.helpers.template] Template variable error: ‘value_json’ is undefined when rendering ‘{{ value_json.state }}’
2023-05-06 22:34:27.762 ERROR (MainThread) [homeassistant.helpers.template] Error parsing value: ‘value_json’ is undefined (value: , template: {{ value_json.state }})
2023-05-07 07:34:39.726 WARNING (Thread-9) [pychromecast.socket_client] [TIM_BOX 8919(192.168.100.66):8009] Heartbeat timeout, resetting connection
2023-05-07 07:35:55.735 WARNING (Thread-9) [pychromecast.socket_client] [TIM_BOX 8919(192.168.100.66):8009] Heartbeat timeout, resetting connection
2023-05-07 07:36:14.221 ERROR (Thread-9) [pychromecast.socket_client] [TIM_BOX 8919(192.168.100.66):8009] Failed to connect to service ServiceInfo(type=‘host’, data=(‘192.168.100.66’, 8009)), retrying in 5.0s
2023-05-07 09:26:18.617 ERROR (Thread-9) [pychromecast.socket_client] [TIM_BOX 8919(192.168.100.110):8009] Error reading from socket.
2023-05-07 09:26:18.619 WARNING (Thread-9) [pychromecast.socket_client] [TIM_BOX 8919(192.168.100.110):8009] Error communicating with socket, resetting connection
2023-05-07 09:52:46.745 ERROR (Thread-9) [pychromecast.socket_client] [TIM_BOX 8919(192.168.100.110):8009] Error reading from socket.
2023-05-07 09:52:46.746 WARNING (Thread-9) [pychromecast.socket_client] [TIM_BOX 8919(192.168.100.110):8009] Error communicating with socket, resetting connection
2023-05-07 09:52:49.805 ERROR (Thread-9) [pychromecast.socket_client] [TIM_BOX 8919(192.168.100.66):8009] Failed to connect to service ServiceInfo(type=‘host’, data=(‘192.168.100.66’, 8009)), retrying in 5.0s
2023-05-07 10:11:23.131 WARNING (Thread-9) [pychromecast.socket_client] [TIM_BOX 8919(192.168.100.110):8009] Heartbeat timeout, resetting connection
2023-05-07 10:11:53.145 ERROR (Thread-9) [pychromecast.socket_client] [TIM_BOX 8919(192.168.100.110):8009] Failed to connect to service ServiceInfo(type=‘host’, data=(‘192.168.100.110’, 8009)), retrying in 5.0s
2023-05-07 19:18:54.387 WARNING (Thread-9) [pychromecast.socket_client] [TIM_BOX 8919(192.168.100.110):8009] Heartbeat timeout, resetting connection
2023-05-07 19:18:57.453 ERROR (Thread-9) [pychromecast.socket_client] [TIM_BOX 8919(192.168.100.66):8009] Failed to connect to service ServiceInfo(type=‘host’, data=(‘192.168.100.66’, 8009)), retrying in 5.0s
2023-05-07 20:25:21.255 WARNING (Thread-9) [pychromecast.socket_client] [TIM_BOX 8919(192.168.100.110):8009] Heartbeat timeout, resetting connection
2023-05-07 20:25:24.333 ERROR (Thread-9) [pychromecast.socket_client] [TIM_BOX 8919(192.168.100.66):8009] Failed to connect to service ServiceInfo(type=‘host’, data=(‘192.168.100.66’, 8009)), retrying in 5.0s
It is the simple service discovery protocol.
A place to start . . .
Please check out this help page and go through the list for any you are using.
