Problem with HAOS with three LAN interfaces
Good afternoon,
We have a home assistant HAOS with three LAN interfaces. On the three interfaces there are static IPs assigned from three different networks. The problem is that after a restart HAOS switches the LAN interfaces and the networks stop working as they should be. Has anyone had the same problem and possibly found a solution?
Home Assistant isn’t a router. Connect it to your router with one LAN cable.
The problem with that is we need broadcast access to three different networks from the Home Assistant. If it could be done with just one interface we would but unfortunately this isn’t the case. I’m just looking for some tips on how to keep the interfaces the same without changing them back after restart every single time.
Then set up directed broadcast forwarding on your router.
