Problem with Homeseer HS-WD100+ dimmer [SOLVED]
Hi, I have a problem with my new dimmer.
I have installed it and tried it before pairing it with my z-wave network and it was working fine.
Since the pairing process i cannot make the dimmer fonction to work locally anymore (light is not dimming just opening very fast to 100% or closing to 100%). The dimmer is working fine if i use Home Assistant to open,close and dim the light.
I tried to do the manual reset provided by the vendor but it’s not working
Can someone help me with that please ?
I’ve been able to solve the issue by removing the electricity from the switch and delete the device from the Open Zwave Control Panel.
When i put the power back to the switch it was working as a standalone so i paired it with my ZWave controller and now it’s working fine.
