I’m trying to put different sensors in a separate file called sensoren.yaml.
To refer to this file from configuration.yaml i add sensors: !include sensoren.yaml
The file is created. The system has rebooted before adding the code. However when trying to validate the configuration.yaml, i get an error: “Component error: sensors - Integration ‘sensors’ not found.”
I cannot figure out why this would not work. Any thoughts?
I’m running Home Assistant OS 6.2 & core-2021.8.8 on a Odroid N2+ device. Installed is MariaDB, Nginx, SSH web terminal, VScode, Samba share, HACS.
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Text to speech
tts:
- platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
http:
# ssl_certificate: /ssl/fullchain.pem
# ssl_key: /ssl/privkey.pem
use_x_forwarded_for: true
trusted_proxies:
- 172.30.33.0/24
ip_ban_enabled: true
login_attempts_threshold: 5
