mandragora
(mandragora)
February 29, 2024, 1:00pm
1
Hello
Once again I have a small problem for beginners.
I am trying to insert the generated script from my Influxdb into Grafana but I get an error message
from(bucket: "home_assistant/autogenous")
|> range(start: v.timeRangeStart, stop: v.timeRangeStop)
|> filter(fn: (r) => r["_measurement"] == "kWh")
|> filter(fn: (r) => r["entity_id"] == "abc")
If I insert this now, I get this error message in Grafana:
InfluxDB returned error: error parsing query: found FROM, expected SELECT, DELETE, SHOW, CREATE, DROP, EXPLAIN, GRANT, REVOKE, ALTER, SET, KILL at line 1, char 1
Unfortunately, my current knowledge ends here and I don’t know what to do.
Can someone please tell me what I am doing wrong here?
Thank you very much for your help and efforts.
Mandragora
koying
(Chris B)
February 29, 2024, 2:33pm
2
Looks like your influxdb is expecting “InfluxQL” (a SQL lookalike) and not Flex as the query language.
See, e.g., Flux vs InfluxQL | InfluxDB Cloud (TSM) Documentation
mandragora
(mandragora)
February 29, 2024, 2:58pm
3
Hello
If I try the same with InfluxQL code I also get an error message.
Is there a setting somewhere in the InfluxDB where I can change / set the query to Flux.
I have set up my Homeassistant with InfluxDB and Grafana according to the usual instructions that can be found on the Internet.
So far everything is working and I get data from the Homeassistant into the database.
Many instructions then show you how to insert the code from InfluxDB into Grafana.
That’s why I want to try this here to learn.
Thank you for the help.
koying
(Chris B)
February 29, 2024, 3:48pm
4
In the configuration of your influxdb datasource in grafana:
mandragora
(mandragora)
February 29, 2024, 6:43pm
5
Thank you koying
When i changed the settings to flux i get this error message
I have tried it with user and password and also without basic auth.
I was only able to restore the settings from the backup so that it worked again.
sorry for my beginner problems.
