hello community,
i have a few difficulties completing my script “disco light”.
With the help of many posts here in the forum, I managed to switch my light to “party mode”.
But now I have to specify in the code which lights should be addressed.
Of course i can do it that way, but if I want to determine for myself which lights should be in “party mode”, I have a big problem defining this.
As I have now understood, I need a certain input_boolean so that I can “filter” my lights in the script:
{% for light in states.light %}
{% set a ='input_boolean.'+light.entity_id.split('.')[1] %}
{%- if is_state( a , 'on') %}
{{ light.entity_id }}
{%- endif %}
{%- endfor %}
however, i don’t know how and where to use this filter …?!?
here you can see the absolutely complex code. maybe a bit gigantic, but it works =)
# _ _ _ _
# (_)_ __ _ __ _ _| |_ | |__ ___ ___ | | ___ __ _ _ __ ___
# | | '_ \| '_ \| | | | __| | '_ \ / _ \ / _ \| |/ _ \/ _` | '_ \/ __|
# | | | | | |_) | |_| | |_ | |_) | (_) | (_) | | __/ (_| | | | \__ \
# |_|_| |_| .__/ \__,_|\__|___|_.__/ \___/ \___/|_|\___|\__,_|_| |_|___/
# |_| |_____|
party:
icon: mdi:PartyPopper
initial: off
# _ _ _
# _____ _(_) |_ ___| |__ ___ ___
# / __\ \ /\ / / | __/ __| '_ \ / _ \/ __|
# \__ \\ V V /| | || (__| | | | __/\__ \
# |___/ \_/\_/ |_|\__\___|_| |_|\___||___/
switch:
switches:
party:
value_template: '{{ states("input_boolean.party") }}'
friendly_name: 'Partymodus'
turn_on:
entity_id: input_boolean.party
turn_off:
- service: input_boolean.turn_off
# _ _
# ___ ___ _ __(_)_ __ | |_ ___
# / __|/ __| '__| | '_ \| __/ __|
# \__ \ (__| | | | |_) | |_\__ \
# |___/\___|_| |_| .__/ \__|___/
# |_|
lights_partying_on:
alias: Lights partying on
sequence:
- service: scene.create
scene_id: studioprimaparty
snapshot_entities:
- light.extended_color_light_2
# - light.extended_color_light_3
# - light.extended_color_light_4
# - light.extended_color_light_5
- service: script.turn_on
entity_id: script.lights_partying
mode: single
lights_partyingv6:
alias: lights_partyingv6
sequence:
- repeat:
while:
- condition: state
state: 'on'
sequence:
- service: light.turn_on
entity_id: light.extended_color_light_2
rgb_color:
- '{{ (range(0, 255)|random) }}'
brightness: 250
transition: '{{ (range(1, 3)|random) }}'
# - service: light.turn_on
# target:
# entity_id: light.extended_color_light_3
# data:
# rgb_color:
# - '{{ (range(0, 255)|random) }}'
# brightness: 250
# transition: '{{ (range(1, 3)|random) }}'
- delay: 1
mode: single
lights_partying_off:
alias: Lights partying off
sequence:
- service: scene.turn_on
entity_id: scene.studioprimaparty
# ___ ___ ___ _ __ ___ ___
# / __|/ __/ _ \ '_ \ / _ \/ __|
# \__ \ (_| __/ | | | __/\__ \
# |___/\___\___|_| |_|\___||___/
- id: '1629180743352'
entities:
input_boolean.party:
restored: true
supported_features: 0
friendly_name: Party ON!
icon: mdi:party-popper
state: 'on'
# _ _ _
# __ _ _ _| |_ ___ _ __ ___ __ _| |_(_) ___ _ __ ___
# / _` | | | | __/ _ \| '_ ` _ \ / _` | __| |/ _ \| '_ \/ __|
# | (_| | |_| | || (_) | | | | | | (_| | |_| | (_) | | | \__ \
# \__,_|\__,_|\__\___/|_| |_| |_|\__,_|\__|_|\___/|_| |_|___/
- alias: 'Lights partying on'
initial_state: true
- platform: state
to: 'on'
service: script.lights_partying_on
- alias: 'Lights partying off'
initial_state: true
- platform: state
to: 'off'
- service: light.turn_off
entity_id:
- delay: 1
- service: script.lights_partying_off
in the code I have “commented out” some entities (- light.extended_color_light_3, - light.extended_color_light_4, etc…) if I “activate” this here, then all lights are in “party mode”
As I said, I am now looking for a solution to add and remove my lights in the dashboard.
suppose I have 4 lights in party mode.
if I now have to / want to take “Light 3” out of there, I need some way of doing this.
I may need to add all “wanted” entities. and use the “filter” (input_boolean) to remove the ones that should be switched off again
can anyone help me ?
