Problem with input_select
Hello ppl after update to HA 2022.3.x my dashboard stopped working properly
I have some input_select inside of horizontal-stack and It doesn’t open under elements, it opens up of and pushes everything down:
Closed:
Open
it becomes unusable
My YAML is:
      - type: custom:vertical-stack-in-card
        cards:
          - type: horizontal-stack
            title: Acções Rápidas
            cards:
              - type: custom:button-card
                icon: mdi:window-closed
                tap_action:
                  action: call-service
                  service: cover.set_cover_position
                  service_data:
                    entity_id: all
                    position: 0
                icon: mdi:window-open
                tap_action:
                  service_data:
                    entity_id: all
                    position: 20
                tap_action:
                  service_data:
                    entity_id: all
                    position: 50
                tap_action:
                  service_data:
                    entity_id: all
                    position: 100
            cards:
                cards:
                  - type: entities
                    entities:
                      - input_select.estores_quartos_sala_actions
                  - type: entities
                    entities:
                      - input_select.estore_cozinha_actions
          - type: divider
            cards:
                entity: switch.carregador_tablet
                styles:
                  grid:
                    - position: relative
                  custom_fields:
                    notification:
                      - background-color: >
                            if (states['sensor.energia_entrada_power_2'].state >= 9)
                              return "#b3ffba";
                            return "#f08181";
                      - color: "#000000"
                      - border-radius: 50%
                      - position: absolute
                      - left: 60%
                      - top: 5%
                      - height: 30px
                      - width: 30px
                      - font-size: 11px
                      - font-weight: bold
                      - line-height: 30px
                      - visibility: >
                            if (entity.state >= "on")
                              return "visible";
                            return "hidden";
                    percent:
                      - color: --mdc-theme-on-primary
                      - left: 39%
                      - top: 35%
                      - height: 30px
                      - width: 30px
                      - font-size: 11px
                      - font-weight: bold
                      - line-height: 30pxurn "hidden";
                custom_fields:
                  notification: >
                    [[[ return states['sensor.energia_entrada_power_2'].state + " W"]]]
                  percent: >
                    [[[ return states['sensor.tablet_bateria'].state + "%"]]]
                icon: mdi:tablet-android
                entity: switch.computador_sala
                icon: mdi:desktop-classic
                entity: light.luzes_presenca
                icon: mdi:floor-lamp-dual
            cards:
                aspect_ratio: 4/1
                layout: icon_label
                label: Desligar tudo
                show_label: true
                show_name: false
                icon: mdi:power
                confirmation:
                    text: '[[[ return `Têm a certeza que deseja desligar tudo?` ]]]'
                tap_action:
                    service: script.desligar_tudo
I think the problem came from this change
any help?
Hello the problem is on vertical-stack-in-card
