Problem with install
I bought a RaspBerry PI 3.
I want to install a home assistant to Raspberry.
During installation, Raspberry has completed installation with an error.
Raspberry wrote to me:
Warning: sudo() received nonzero return code 1 while executing ‘ln -sd /srv/hass/hass_venv/lib/python3.4/site-packages/libopenzwave-0.3.1-py3.4-linux-armv7l.egg/config’!
And putty wrote to me too:
Server unexpectedly closed network connection
What is wrong?
How to fix this error and continue installing Home assistant?
Make sure that your SD card has enough space.
I have a 32gb sd card and im getting this exact same error
[localhost] sudo: git clone https://github.com/OpenZWave/open-zwave-control-panel.git
[localhost] out: fatal: destination path 'open-zwave-control-panel' already exists and is not an empty directory.
[localhost] out:
Warning: sudo() received nonzero return code 128 while executing 'git clone https://github.com/OpenZWave/open-zwave-control-panel.git'!
[localhost] put: Makefile -> /srv/hass/src/open-zwave-control-panel/Makefile
[localhost] sudo: make
[localhost] out: make: Nothing to be done for 'all'.
[localhost] out:
[localhost] sudo: ln -sd /srv/hass/hass_venv/lib/python3.4/site-packages/libopenzwave-0.3.1-py3.4-linux-armv7l.egg/config
[localhost] out: ln: failed to create symbolic link ‘./config’: File exists
[localhost] out:
Warning: sudo() received nonzero return code 1 while executing 'ln -sd /srv/hass/hass_venv/lib/python3.4/site-packages/libopenzwave-0.3.1-py3.4-linux-armv7l.egg/config'!
same here, tried several time after re-image it. no luck, every time it reboots at here.
